w.o.t. shift rpm 1st to 2nd. gear?
Old Nov 27, 2009 | 06:47 PM
Racinartist's Avatar
Racinartist
Originally Posted by Q-TIP
And factory tachs are notoriously inaccurate. I had my Dak (2009) on the dyno the other day and my factory tach was reading 5900rpm when my crank pully was only spinning around 5450. Once the needle leaves idle it looses accuracy. The only part of your truck that gets a truly accurate RPM reading is the ECU and it passes that along to the tach that then has to reinterpret the signal and doesn't always keep up. The biggest difference I have ever seen are the Yamaha R6V's, the tach would read 16,500rpm while the ECU was logging ~14,100rpm
Now that you brought it up, here's an interesting read about Yami's R6Vs.
In 2006, Yamaha advertised that the R6 had a redline of 17500 rpm. This is 2000 rpm higher than the previous R6 model and was the highest tachometer redline of any 2006 production four-stroke motorcycle engine.[citation needed]
Hypothetically, if it was the actual engine RPM, it would be at levels previously known only in Formula One engines, where valve spring stress problems lead to the adoption of pneumatic valve actuation to handle more than 19,000 rpm.[1]
It was widely reported that the 2006 YZF-R6's motor did not have this engine rpm redline level and was closer to around 16200 engine rpm, but because of a deliberate tachometer error of about 9%, it read 17,500 tachometer rpm. In February 2006, Yamaha admitted the bike's true engine redline was more than 1000 rpm lower than displayed on the tachometer than advertised,[2] and offered to buy back any R6 if the customer was unhappy."
Hahahaha
Old Nov 28, 2009 | 12:32 PM
Q-TIP's Avatar
Q-TIP
Ha ha, and the funny thing is they didn't even reach 16,200 rpm. To this day tuners know that the highest the R6 engine spins from the factory is 15,000. However it can handle up to 16,500 without issue when the rev-limiter is increased.
