new meats
Old Dec 1, 2009 | 03:04 PM
Dinger838's Avatar
Dinger838
Default new meats
well bit the bullet and bought four new BFG m/t 255/75/17 for 568 plus 90 for shipping should be here in a couple days ill post pics then. how bad will this kill my mileage? lol i plan to do 4.10 gearing once i get the cash
Old Dec 1, 2009 | 03:11 PM
dodgetrucker75's Avatar
dodgetrucker75
well they are 32.1 x 10 inch so probaply wont be too bad, when i went to my 33x12.50's, i only lost .5 mpg's. just make sure you recalibrate correctly for the new tire size, or it will be way off
Old Dec 1, 2009 | 03:21 PM
Dinger838's Avatar
Dinger838
thank you i should be installing my tranny cooler today or tommorrow. and DT75 your truck amazing btw. whats a good psi for on road?
Old Dec 1, 2009 | 03:29 PM
dodgetrucker75
i normally start with the pressure that is on the tag on the inside of the driver door, then adjust from there, between your ride quality and wear, if you start wearing the centers=to much psi, and wear on the edges=not enough psi. its always a big guessing game with new and bigger tires, just keep a good eye on them.
Old Dec 1, 2009 | 03:34 PM
paul05dak's Avatar
paul05dak
instead of inside the door, shouldn't you go by what is stamped on the tire? I figure, the tire manufacturer would know better than Dodge.
Old Dec 1, 2009 | 03:41 PM
dodgetrucker75
only thing stamped on the tire is the maximum psi they can operate at with out exploding, running at the max (on these light truck tires anyway) will give you a rough ride and wear out the center of your tires, dodge does know better in this case because the pressure is set for the weight of the vehical, thats why i said start there, then adjust if you have too
Old Dec 1, 2009 | 04:02 PM
Dinger838's Avatar
Dinger838
thankkkk you lol
Old Dec 1, 2009 | 04:22 PM
popsnbeer's Avatar
popsnbeer
I think our trucks say 35 psi front and rear. I usually stick around 38-40 for a little better highway mileage. Also it keeps the tread a little more even for my truck.
Old Dec 2, 2009 | 07:01 AM
sdsdsd's Avatar
sdsdsd
How do you recalibrate for the different tire size?
Old Dec 2, 2009 | 09:39 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
A Tuner or the Dealership, is your best bet
