05-06 dak lift? and electrical prob
Old Dec 8, 2009 | 03:18 PM
dodgetrucker75's Avatar
dodgetrucker75
like i said before... there is no way that will work with a 4x4, if it corrects ball joint angle, that means its also going to travel further, and if there is any more travel than the stock upper arm, the cv shafts WILL come apart. and what about the lower arm, its going to be getting close to vertical and sucking the tire into the frame, this will severly limit tire size, and there will probably be no where near the amount of adjustment required on the lower arm to correct camber angles... thats enough ranting for now, but im sure i can come up with more
EDIT: and one other thing... i looked, and no where does it even state it is for a 4x4
Old Dec 8, 2009 | 08:00 PM
Altair's Avatar
Altair
Dak attack!
Before you even think about buying spend some time on google and research AIM Industries, Chassis Tech, AirBagIt and Joe Morrow's other companies. The guy even wanted to sue a forum for members advising others to stay away: www.streetsourcemag.com/email2.htm
It's up to everyone whether or not they want to deal with these guys, just make sure you go into it informed.
Old Dec 8, 2009 | 08:24 PM
Frenchy's Avatar
Frenchy
Originally Posted by lvo6
has anyone tried the following lift http://www.airbagit.com/product-p/x2-car-dk05xxc.htm ?
Also i bought my 06 v6 quad cab a couple of months ago, and since its been getting colder out, every morning when i start my truck the wipers go off and spray for about a minute, and also the dash lights kinda flash really bright for a sec. Is this a recall for the cluster to be re-flashed or does anyone know?
Thanks
My truck sometimes does the cold wiper random turning on thing.... never sprays, though. I usually just rotate the turn ****, and it stops.
Old Dec 8, 2009 | 09:24 PM
dodgetrucker75
WOW!!! thats out of control...
Old Dec 8, 2009 | 10:30 PM
05dakota4x4's Avatar
05dakota4x4
chassis tech, air bagit there stuff is nothin but junk
