Questions about my Radier
When I counted the Rear Bolt on the Diff I counted 11
I want to know if it is an 8'' or 9.25'' rear end.
This is all I counld find on specs
2008 Mitsubishi Raider LS Crew Cab Pickup Performance & Efficiency Standard Features -
3,701 cc 3.7 liters V 6 front engine with 93.0 mm bore, 90.8 mm stroke, 9.7 compression ratio, overhead cam and two valves per cylinder EKG
Unleaded fuel 87
Fuel economy EPA highway (mpg): 22 and EPA city (mpg): 16
Multi-point injection fuel system
22.0 gallon main unleaded fuel tank 18.3
Power: 157 kW , 210 HP SAE @ 5,200 rpm; 235 ft lb , 318 Nm @ 3,600 rpm
2008 Mitsubishi Raider LS Crew Cab Pickup Handling, Ride & Braking Standard Features -
Rear-wheel ABS
3.550:1 axle ratio
Two disc brakes including two ventilated discs
Fullsize under body spare wheel
Wishbone front suspension independent with stabilizer bar and coil springs, beam rear suspension rigid with leaf springs
2008 Mitsubishi Raider LS Crew Cab Pickup Exterior & Aerodynamics Standard Features -
Body side molding
Body color front and rear bumpers
Driver and passenger power black door mirrors
External dimensions: overall length (inches): 219.9, overall width (inches): 71.9, overall height (inches): 68.6, ground clearance (inches): 7.9, wheelbase (inches): 131.3, front track (inches): 62.8, rear track (inches): 62.9 and curb to curb turning circle (feet): 44.0
Front fog lights
Complex surface lens halogen bulb headlights
Pearl paint
Straight side pickup bed
Sliding rear window
Rear platform step
Tinted glass on cabin, rear and side
Trailer towing preparation
Weights: gross vehicle weight rating (lbs) 6,010, curb weight (lbs) 4,415, gross trailer weight braked (lbs) 4,050 and max payload (lbs) 1,590
Windshield wipers with variable intermittent wipe
2008 Mitsubishi Raider LS Crew Cab Pickup Interior Standard Features -
12v power outlet: front and 1
Air conditioning
Roof antenna
Audio system with AM/FM and CD player CD player reads MP3
Automatic drive indicator on dashboard
Cargo area dimensions: front width (inches): 59.6 and height (inches): 17.6
Cargo area light
Cargo capacity: all seats removed (cu ft): 37.1
Rear tailgate cargo doors
Clock
Dashboard console, partial floor console with open storage box
Delayed/fade courtesy lights
Cruise control
Front seats and rear seats cup holders fixed
Door ajar warning
Door pockets/bins for driver seat, passenger seat and rear seats
Floor covering: carpet in load area
Floor mats
Driver front airbag with multi-stage deployment, passenger front airbag with occupant sensors, occupant switch off and multi-stage deployment
40/20/40 split driver, passenger and center seat
Height adjustable 3-point reel front seat belts on driver seat, height adjustable 3-point reel front seat belts on passenger seat, lap static front seat belts on center seat
Front seat center armrest
Two height adjustable head restraints on front seats, two head restraints on rear seats
Illuminated entry system
Internal dimensions: front headroom (inches): 39.9, rear headroom (inches): 38.4, front hip room (inches): 54.9, rear hip room (inches): 56.0, front leg room (inches): 41.9, rear leg room (inches): 36.4, front shoulder room (inches): 57.7 and rear shoulder room (inches): 57.5
Low tire pressure indicator
Remote power locks
Power steering
Front power windows with one one-touch, rear power windows
Front reading lights
3-point reel rear seat belts on driver side, passenger side and center side
Three asymmetrical split bench front facing rear seats with zero adjustments
Rear view mirror
Cloth seat upholstery with additional cloth
Seating: six seats
Four speaker(s)
Plastic multi-function steering wheel with tilt adjustment
Tachometer
Driver and passenger vanity mirror
Ventilation system
Read more: http://www.motortrend.com/cars/2008/...#ixzz0ZaaASEAh
Unleaded fuel 87
Rear-wheel ABS
3.550:1 axle ratio
Body side molding
Front fog lights
Pearl paint
Sliding rear window
Rear platform step
Air conditioning
Roof antenna
Cargo area light
Clock
Cruise control
Door ajar warning
Floor mats
Remote power locks
Power steering
Rear view mirror
Seating: six seats
Four speaker(s)
Tachometer
Ventilation system
x2. I just scrolled through it all.
Trending Topics
Also, this is identical to a post he made about a week ago. The conclusions were:
For a 4.7L swap the 8.25" will probably hold up for a while
For a 5.7L swap the 9.25" is the better choice
Also, it was advised that swapping engines is a bitch, especially with OBDII vehicles, not a casual project.
I don't know why you would step back in time to a 5.2L.
how much power can it hold? If I swap to 4.7L should i swap the rear end? Also woulding the 5.2L fit as well at the 5.7l
