Founds 3.7L header
Old Dec 15, 2009 | 09:56 PM
sullysdetailing's Avatar
sullysdetailing
Default Founds 3.7L header
JBA makes headers for the 3.7L Ram and Nitro. Now all we have to do is figure out which ones fit better
Old Dec 15, 2009 | 10:21 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
I would guess the Ram, only for the reason that I would guess the clearances would be about the same on the Ram as on the Dakota...
Old Dec 17, 2009 | 03:26 PM
Frenchy's Avatar
Frenchy
mmm Idk, Billy, the ram has a LOT more space under the hood... they may be made to be further away from the block... if that makes sense...
But, for the two options listed, I'd guess the ram, as well.
...actually, maybe the Nitro, it has a narrower engine bay, the headers may be tucked in differently.
Idk, putting too much thought into this.
Old Dec 18, 2009 | 02:12 AM
Slick Dakota's Avatar
Slick Dakota
I cant wait to hear how it works for you and how it sounds, I may have to get some .. Cya Slick
Old Dec 19, 2009 | 08:51 PM
Slick Dakota
I was looking under the hood today to see how hard it may be to get them on, Well the drivers side not to bad, other then the steering shaft.. Passengers side is a whole other ball game there is enough on the mod list for the time being but wont forget this post.. Cya Slick
Old Dec 21, 2009 | 11:23 PM
sullysdetailing
Also found the Power Wire from Air Ram
Old Dec 22, 2009 | 08:10 AM
lghtngblt02
I honestly don't believe you know what you are talking about... more space is what he needs, not less or narrower.
Old Dec 22, 2009 | 08:08 PM
Altair's Avatar
Altair
Dak attack!
Do a search of this section for power wire, it's quite easy to make your own, just need a resistor.
Old Apr 14, 2010 | 03:25 AM
DodgeThumper378's Avatar
DodgeThumper378
Got an email from JBA and they suggested the RAM headers as long as the exhaust manifold is the same, going to call later this week
Old Apr 14, 2010 | 11:34 AM
popsnbeer's Avatar
popsnbeer
I thought there was a thread about this like 6 months ago. Someone had suggested using the Nitro headers, but they ended up not fitting.
