Finding aftermarket wheels
I found these:
http://www.tirerack.com/wheels/MiniW...=true&sw=1440#
Very close to the look I want.
I know there's another thread about offset. Is the -12 offset a bad thing? Also, I see the rims are 17x9. What will happen when I put my tires on them? The rims I currently have are 17x8. Yes, tires are P265/65R17
Slick Dakota measured the offset on 18X8 rim, & determined that it was +38.
Not sure on 17x8 rims.
https://dodgeforum.com/forum/3rd-gen...nd-offset.html
Trending Topics
I just ran a tape measure on my spare set of rims, they match what I have in the picture of my truck, and I am now even more confused. They don't appear to be 17x8. I measured from outside the rim to the other outside and got about 9.5 inches. Did I measure them wrong? Or is it the inside of the bead that I measure? I figured they were 17x8 because someone told me that's what they are.
I was told my rims were 17x8.5
Yours might be the same.
From reading the other thread the -12 offset is a bad thing, means the tire will be in the wheel well farther and will rub on the inside easier. you should have a +38 off set on the stock 17" rims.
any thing above 0 is ok from what I understand. don't go into the nagitive #'s
