Trans Cooler Line Leak
Old Jan 6, 2010 | 10:29 AM
mprohr's Avatar
mprohr
Default Trans Cooler Line Leak
My Transmission Cooler Line is leaking where the rubber hose meets the metal fitting between the motor and the radiator. Small drips. My guess is super cold weather is taking its toll on the fitting. Any advice or cost estimates from anyone who may have had this problem? I know Biker Ahoy started a post on this (see link below), but it never went any further than to say it was fixed under warranty. Most of the thread was hi-jacked by cracked fog light lenses
https://dodgeforum.com/forum/3rd-gen...of-engine.html
Old Jan 6, 2010 | 12:49 PM
canadian dakota's Avatar
canadian dakota
I have the same problem actually it went into the dealer this morning its gonna be 96cdn plus tax including parts and labour and parts at 10% above cost
Old Jan 6, 2010 | 02:09 PM
biker_ahoy's Avatar
biker_ahoy
Yes I had the same issue, it was fixed under warrenty. no problem since!
Old Jan 6, 2010 | 02:56 PM
canadian dakota
they won't warrenty mine but maybe 70000 k has something to do with that
Old Jan 6, 2010 | 03:08 PM
biker_ahoy's Avatar
biker_ahoy
ya, I had under 30000 when I got mine replaced.
Not sure what the cost on that would be, be shouldn't be too bad, its just a hose with fittings on each end.
Old Jan 6, 2010 | 05:17 PM
mprohr's Avatar
mprohr
Mine has 70k too. I havent taken a very hard look yet. Just noticed a couple of 3-4 drip puddles in the drive and saw it was coming from that fitting. It's probably fine when warm, but when it gets down to zero at night, the fitting shrinks and hardens. So I will replace it. Anyone replaced it themselves? From a glance, you couldn't see the ends of the lines as they went back through the motor, and under plastic at the radiator.....and it's too damn cold to get on the ground.
Old Jan 7, 2010 | 12:03 AM
dodgetrucker75's Avatar
dodgetrucker75
just a quick thought for a DIY repair, you could cut the aluminum lines, just the other side of the rubber hoses, put a small flare on it for insurance (napa sell the simple tools to do this very cheap) then just put a new rubber hose and some clamps on...
Old Jan 7, 2010 | 02:59 AM
canadian dakota
i called napa they sell a hose repair kit dunno the price i just sent it to the dealer $130 to stay outta the snow i did take some pics of how they are ran hope this helps
PICT0001.jpg?t=1262850454
from the rad round the oil pan
PICT0005.jpg?t=1262850560
down the right side over the cross member
PICT0006.jpg?t=1262850699
back towards the trans
PICT0008.jpg?t=1262850849
can see the drain plug here lines run over the exhaust
PICT0007.jpg?t=1262851011
looking straight up from beside the trans pan i found this i believe would be the right line it would only make sense hope this helps lemme know if you decide to do this
Old Jan 7, 2010 | 10:58 AM
mprohr's Avatar
mprohr
Thanks guys. Looks like a pretty easy swap.....but $130 doesnt sound too bad. I think I may have hit a snow bank after some reflection. I'm gonna pony up for a skid plate if they damage that easily.
