roller rockers
Old Jan 13, 2010 | 07:57 PM
keachers's Avatar
keachers
Default roller rockers
are any of you guys running them? i went to the krc performance website and found some but im unsure about buying them bc i dont wanna spend money and have them not work. also does anyone know about the 206 cam and where to find it. do we need a certain model number or something. if so can you please help me out and give it to me. thanx
Old Jan 14, 2010 | 08:59 AM
superdak05's Avatar
superdak05
forget about rollers, our trucks have what is compatible to the roller, because of the cam design, an yes krc sells the 206 cams
Old Jan 14, 2010 | 10:15 AM
trucky's Avatar
trucky
When I first got my truck my original forum was dodgedakotas.com; those guys raged about rollers for the 4.7. I am quite surprised no one mentions it on these forums... back then 3rd gen was a new model though and most of these guys were 2nd gen.
Old Jan 14, 2010 | 05:54 PM
keachers's Avatar
keachers
so after you bought the cam what else did you have to do or modify? i know i have to get the pcm reflashed so how long does that take?
Old Jan 16, 2010 | 09:40 AM
superdak05's Avatar
superdak05
simple cam swap, our lash caps are compatible to 1.8 roller rockers, so i did not have to change them, than a custom tune from marty at krc, it takes some time to get the correct tune, everything is done over the internet. to this day, i am still getting tunes, still messing with my nitroous an now that my convertor is in, we will have new numbers soon.
Old Jan 16, 2010 | 01:03 PM
keachers's Avatar
keachers
so your saying that my downtime on my truck is very minimal like a weekend?
Old Jan 16, 2010 | 01:13 PM
superdak05's Avatar
superdak05
for a simple cam swap, about 6 hrs. if you have help, there is a thread somewhere that has a detailed tear down an swap, you may have to google it, took this guy 13 hrs to do, also you need the correct tools an spanner wrenches, that was his problem, not the correct tools or wedges. google search, 4.7 cam swap
Old Jan 16, 2010 | 01:31 PM
keachers's Avatar
keachers
alright man thank you so much. one more question. how do you get the program from the internet to your truck?
Old Jan 16, 2010 | 03:14 PM
Blown287's Avatar
Blown287
Cam swaps are fairly simple as long as you do your research. Takes about 4-6 hrs as mentioned above and I made my own wedge tool out of wood.
Just remember
HO cams = direct replacement
206 cams = lash caps
212-224 = lash caps, beehive valve springs and custom tunning.
