Help with security alarm
Old Jan 22, 2010 | 10:41 PM
Hartman-52's Avatar
Hartman-52
Default Help with security alarm
I have a 2006 Dakota SLT and I can't get the factory security alarm to work. When you start the engine, the instrument cluster security light comes on momentarily indicating that the bulb is OK. When you lock the doors with the remote fob, the security light does not come or flash and if the locked door is opened from the inside, the alarm does not go off. Haven't found any burnt fuses in fuse box and everything else works OK. What fuse number is used for the alarm? Is there a reset function to correct this or another way to arm the system?
Old Jan 23, 2010 | 03:08 AM
superdak05's Avatar
superdak05
first off, if the truck senses a key inside the vechicle. the alarm will not go off. sharons nitro had an issue an the service manager told us that. if the truck was bought used. the previous owner might have disabled it. check the owners manual. you may need to reverse the steps to get it to work. also try this. lock the truck with the fob. than use the key in the door to unlock truck, open door an see if alarm goes off. if it does. you will need to start an stop truck 2 times to get alarm to turn off
Old Jan 23, 2010 | 07:58 PM
Hartman-52's Avatar
Hartman-52
I tried your suggestion but the alarm still doesn't work. If the previous owner disabled it, how can it be re-enabled? All the manual says is to set the alarm you press the door lock on the fob and then its set. There is no mention of a reset or how to enable the alarm if it was turned off.
Old Jan 23, 2010 | 10:51 PM
moFaster10's Avatar
moFaster10
is it possible that maybe yours doesn't have an alarm ?.. check with the dealership
