05 Dakota Lift Kits for 6 spd Manual
Old Jan 28, 2010 | 02:22 PM
sportinaf02's Avatar
sportinaf02
Default 05 Dakota Lift Kits for 6 spd Manual
I have an 05 Dakota with a 6 spd manual tansmission. I want to lift it, but can't find any real info it is possible? Any info will be appreciated.
Old Jan 28, 2010 | 02:26 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
leveling kit for the front. 2" Blocks for the rear. Thats 2" all the way around.
3" body lift, you will need to get your shifter extended, that doesnt come with the kit.
Finally larger tires, you can get another 1/2 to 1" lift from taller sidewalls depending on which factory size you have.
Thats it.
Old Jan 28, 2010 | 06:33 PM
sportinaf02
Thanks for the heads up. Do you recommend any particular 2" lift for the front, the 3 in body lift all around, and the shift extender?
Old Jan 28, 2010 | 08:47 PM
Altair's Avatar
Altair
Dak attack!
Are you 4x4 or 4x2, and if you're 4x4 do you do much wheeling?
Old Jan 29, 2010 | 09:39 AM
sportinaf02
Yes I have a 4X4 and yes I will be doing some off roading, but not a whole lot.
