New Driving Lights!
Old Jan 29, 2010 | 11:55 AM
canadiandodge's Avatar
canadiandodge
looks good man i like it alot
Old Jan 29, 2010 | 02:47 PM
babygotdak's Avatar
babygotdak
I just noticed that your rack is attached by rails. Did you have those put on aftermarket? Mine attaches around the door seal and it pushes my doors out a bit. I think the cold noise is due to the door seals contracting in the cold weather.
Old Jan 29, 2010 | 03:55 PM
biker_ahoy's Avatar
biker_ahoy
Ya that was one of the reasons I went with the rails, the rubber prob doesn't seal on either side of the clip.
My Rails are a Yakima aftermarket setup, Had the rails permanently install on the roof,
so I don’t have any noise from the doors, just the fairing makes noise. (Stereo take care of that easy)
I wanted this setup because less then 2 minutes and I can have the crossbars removed or reinstalled, + the 160lb rating with this setup is more than enough for my needs.
Old Jan 29, 2010 | 04:10 PM
babygotdak's Avatar
babygotdak
What did the rails run you?
Old Jan 29, 2010 | 05:08 PM
biker_ahoy's Avatar
biker_ahoy
The rails themselves are around the $200 mark if I remeber right,
My whole setup including install came to $800CAN
The install also comes with a lifetime warrenty against defects.
Rackattack based out of the Vancouver area was the place I picked mine up at. there website is "RackAttack.com"
FYI - the Thule and Yakima rails are exactly the same. the thule's are cheaper though. I got the 54" rails and had them cut shorter to fit the roof as the 42" was a little shorter than I wanted. I think the length on mine are 46" long, front to back.
