SUBS what do i do
Old Jan 31, 2010 | 05:16 PM
mxdakota47's Avatar
mxdakota47
Default SUBS what do i do
ok so i went through and tried to find the sub threads but i couldnt really dig anything up. I want to put two subs in 2007 QC dakota. So i read that biker ahoy had kickers and if i can i wanna go with kickers but im also open to Alpines. So basically i need to find out what i can put in my truck thats going to sound kick *** but cheap becuase im 16 and dont have tons of money. so does anyone else have two subs in there truck? i know im going to mount them behind the rear seats and am going to need a custom a box. So if kickers what do i need and if Alpines what do i need
Old Jan 31, 2010 | 08:16 PM
spshultz's Avatar
spshultz
Here are the dimensions for the sub box behind the rear seat on the drivers side I believe.
Top depth: 3.5inchs
Bottom Depth: 7.75inches
Width: 13 inches
Height: 13.75 inches
I think you'll only have about 5.5" of mounting depth so you'll have to go with a sub that doesn't mount to deep. In addition to the Kicker and Alpines you could try Elemental Designs or maybe some used Adire subs. If I had the mounting depth I'd go with two Brahma's. Oh, and Infinity used to make some decent shallow mount subs also.
Old Jan 31, 2010 | 09:34 PM
nola24's Avatar
nola24
I'm 16 and just did my system as well.. I had already gotten regular depth subs so I couldn't put them behind the seat. I took out the front middle seat and put a custom box there. The guy that built it said I could fit two tens, but he built it for one sub so I could only use one of my alpine type E 10". Check out my cardomain for pics. www.cardomain.com/id/nola24
Old Jan 31, 2010 | 09:49 PM
mxdakota47's Avatar
mxdakota47
nice but it looks like you took the center console out im trying to keep the regualar interior. I see you got a MX bike, thats why i got my dakota was so i load my bike by myself becuase i race alot and have a trailer but it looks good man i want a flip up screen like that
Old Jan 31, 2010 | 11:51 PM
raiders98's Avatar
raiders98
I got an ext. cab, I removed the back seat behind the Driver's side, and built a slanted box behind it. I have a 15" Kicker L7. Pretty loud
Old Feb 1, 2010 | 02:09 AM
biker_ahoy's Avatar
biker_ahoy
If you feel a little brave you could do what I did, this calls for removing the Jack bracket from behind the passanger rear seat, this way you can put a bit bigger of a box back there, which will help with better sound. I have the 10" shallow Kicker,sub with shallow kicker box, and it rocks plenty.
here's some pics
http://carphotos.cardomain.com/ride_...0051_large.jpg
http://carphotos.cardomain.com/ride_...0021_large.jpg
Doing this means you won't be able to fold the seat up all the way but you still have access to item under (pic) that's as high as it will go with the box behind.
http://carphotos.cardomain.com/ride_...0040_large.jpg
Cheers
Old Feb 1, 2010 | 07:31 AM
mxdakota47's Avatar
mxdakota47
yea im deffaintley down with removing the bracket but i want to run 2 10s so does anybody else have one behind the driver rear seat? like is there a way i could do the exact same thing behind the passenger rear seat
Old Feb 1, 2010 | 08:29 AM
canadiandodge's Avatar
canadiandodge
i have one behind just the driver seat it fit fine and i have the amp under the bottom. there is many others on here that have it that way also i fit 1 10 jl behind the drivers rear seat.
Old Feb 1, 2010 | 09:34 AM
biker_ahoy's Avatar
biker_ahoy
You could look at having a custom box built to fit over the seat brackets and it could be a single box with two 10" subs. that would be cool to see! but might cost more.
Old Feb 1, 2010 | 11:41 AM
silverdak4x4's Avatar
silverdak4x4
it is possible to build a dual 10" box over the rear hinges takes some time but this one came out great plus there is room under set for the amp and the extra space under the box on the passenger side is perfect for a 2 farad cap.
File Type: jpg
