Need help on purchasing Flowmaster Muffler
Old Feb 2, 2010 | 06:27 AM
marker227's Avatar
marker227
Default Need help on purchasing Flowmaster Muffler
Hey all,
I had the Flowmaster 40 series muffler on my V8 4.6 Mustang and I really loved the sound. It wasn't too loud, or too aggressive. It was perfect.
I'm wanting to put that same muffler on my truck, but I'm having a bit of trouble figuring out which 40 series muffler I'm looking for.
http://www.autoanything.com/Accessor...max+rel+static
There is a "Delta Flow" and an "American Thunder" 40 series. I don't know which one I had on my mustang...
By the way, I have a single tailpipe.
Thanks guys!
Could you guys also please tell me which kind of muffler I need for my truck? I have a stock exhaust on my 2005 Dakota V8. I don't know if I want a center inlet/center outlet, center inlet/offset outlet, etc.
http://www.autoanything.com/exhausts...A2512A0A0.aspx
Old Feb 2, 2010 | 09:47 AM
moFaster10's Avatar
moFaster10
i got a super 44 american thunder single in dual out dumped and its loud ..and way agressive.. but thats the way i like it
Old Feb 3, 2010 | 05:10 AM
marker227's Avatar
marker227
Can anyone help me out?
Old Feb 3, 2010 | 07:32 AM
paul05dak's Avatar
paul05dak
I have a delta 55 series, need to have Offset Inlet / Opposite Side Offset Outlet 2.5 in pipe. Can't help as far as sound for the 40 american thunder vs delta. I can tell you I really love the sound of my delta 50. Kept the front resonator on removed the back.
Old Feb 3, 2010 | 08:41 AM
spshultz's Avatar
spshultz
I've had both but not on this truck.
The Delta Flow for me had a slightly more smooth sound than the aggressive Thunder 40. And when I mean slightly I mean just a hair.
If I were to use one of these I would order it about .5" to 1" larger in pipe I.D. size than I need since they don't flow quite as well as some other mufflers.
As for drone, I've run 3 different mufflers on my Dakota and they all droned badly. That is until I cut the tail pipe off and dumped it just over the axle and pointing at a 45 degree angle.
Also, if I were to do it all over again I'd probably keep the rear resonator and remove the front resonator.
As for what position inlet/outlet to get I really can't say. If you are going to have an exhaust shop do it I'm sure they can work with what ever you get.
