Alternator Question ?
Old Feb 3, 2010 | 01:41 PM
biker_ahoy's Avatar
biker_ahoy
Default Alternator Question ?
Was thinking about this with all the stereo amps, and other power drawing items I have on the truck and more planned to install
Is there a higher output alt for either the 4.7 or 3.7 motors?
I believe the 4.7 is a higher output than the 3.7, But can you swap them between engines or do they have different mounting?
Old Feb 3, 2010 | 04:28 PM
canadian dakota's Avatar
canadian dakota
I had the same question a while back I installed some extra lighting on my 08 which has a 136 amp alt. this being said some one had mentioned the caravan alt now. idk if its a bolt on but it is an 160 amp alt I believe try looking up the thread "bright idea" there where some things mentioned that will help haven't had much time lately to invest into my truck its been busy at work
