help with leveling kit
Old Feb 8, 2010 | 10:35 AM
whiteram00's Avatar
whiteram00
Default help with leveling kit
does anyone on here have a step by step instructions of how to do this,i got the 2 inch spacers for the front.4 wheel drive of course how hard are they to install(1-10)
how long does it usually take and what all tool are needed
Old Feb 8, 2010 | 01:04 PM
06firedak's Avatar
06firedak
just put one on mine, you will need a strut spring compressor if your replacing the struts( i recommend this since you already have it tore down) other than that it can be done with common hand tools. I chose not to seperate the ball joints and removed the upper a arm at the frame instead. so, i did the front spacers, struts, rear 2 inch blocks, and threw in a tie rod end and took me about 5 hours. but to just add the front spacers i would say about 2 hours. good luck
Old Feb 9, 2010 | 11:56 PM
whiteram00's Avatar
whiteram00
anybody else with a step by step or pics
Old Feb 10, 2010 | 12:35 AM
dodgetrucker75's Avatar
dodgetrucker75
here ya go....
https://dodgeforum.com/forum/3rd-gen...stall-diy.html
