overhead display mpg's?
Old Feb 11, 2010 | 03:37 PM
dodgetrucker75's Avatar
dodgetrucker75
Default overhead display mpg's?
just thinking about my last fill up... i drive at least 300 miles before toping off the tank, and i cant recall ever putting more than 17-18 gallons in, which comes out somewhere 16.5-17.5 mpg's,(at the worst i have ever done), however the overhead display has never showed anything over 12.8 anyone else noticed this, or is my system screwed up? at least now i feel a little better about the milage...
Old Feb 11, 2010 | 04:55 PM
paul05dak's Avatar
paul05dak
me too, the over head display is not accurate for the MPG. hell even the temp is a few degrees off...
Old Feb 11, 2010 | 05:19 PM
bain64's Avatar
bain64
You must be getting highway miles man! I average more like 14 in town with stock rubbers. My overhead reads a little better than I actually get.
Old Feb 11, 2010 | 06:07 PM
dodgetrucker75
not to many hwy miles, at the very most maby a 1/4 of the miles are on the hwy
Old Feb 11, 2010 | 07:44 PM
Moneyman19's Avatar
Moneyman19
mmm well i like ur bumper i want one just like that just without the bush guards, im thinking maybe its ur weight? maybe with the extra weight its calculating theres more load? just thinking out loud
Old Feb 11, 2010 | 08:13 PM
lmrjason's Avatar
lmrjason
i wish the console did current mpg like the ram does...the average mpg are way off.
Old Feb 11, 2010 | 11:18 PM
italiandominator's Avatar
italiandominator
Did you compensate your speedometer when you put on bigger tires? Obviously, when you increase the size of your tires, it can throw off your speedometer, cuz you are going a little faster than its telling you, but also your going more miles than it might say you are. Also, if you did reset it, the mpg computer might not have compensated. All I know is when I had OEM tires on mine I was getting about 19-20 mpg (about 50/50 Hwy/Cty), after I changed them I get about 17-18. Also, I was getting about 325 miles a tank (with a 17-18 gal top off), granted I took it down low. Now I always try to fill up when it hits about a 1/4 and I'm getting about 250-260. If there is something I can do to boost my mpgs I'm all for it, at least I can afford it for now.
Old Feb 12, 2010 | 01:09 AM
bain64's Avatar
bain64
How did you take it down low with a 17-18 gallon top off? I've got a 22 gallon tank, is the 2005 dak less?
Old Feb 12, 2010 | 10:25 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Mine has been generally close... with in 0.5 mpgs, I usually hand calc it just to make sure.
Old Feb 12, 2010 | 10:42 AM
jnd03's Avatar
jnd03
I just bought a 2005 DAK I dont know the size of the tank is it 18 gal? or 22? when i got it the tank was on full. i have driven it for 120 miles all city driving and driving it like a baby and the tank is half full, does this mean i am going to get about 230 and 240 miles per tank? if the tank is 22 gallons thats an avreage of about 10.68 mpg! YIKES!!!
