tires and rims?
Old Feb 16, 2010 | 03:12 AM
nicholas9393's Avatar
nicholas9393
Exclamation tires and rims?
i purchased the daystar leveling kit, 2 in blocks for the rear and im waiting till next weekend to put them in. i also bought a set of 265/75 r16 nitto dune grapplers that look freakin awsome (plus i do all my offroadin out here in the desert). my question is what size rim should i be looking to get? obviously a 16 in rim, but should it be 16x8? 16x10? how much backspacing do they have to have? and the lug pattern is 5-5.5 correct? thanks
Old Feb 16, 2010 | 01:00 PM
TRX4_2008's Avatar
TRX4_2008
16 x 8 is correct with 5 x5.5. I can't remember the backspacing but and good wheel dealer (Tire Rack) can tell you what offsets will work.
Old Feb 16, 2010 | 04:38 PM
bigbotes69's Avatar
bigbotes69
16x8. I think the backspacing was 114mm.
Old Feb 18, 2010 | 01:40 AM
nicholas9393
cool thanks. but a problem just came up, apparently nitto just quit making 265/75 dune grapplers had em ordered on jcwhitney n all a sudden it says line cancelled. has anyone been able to fit 285/75 with 2" front and back lift? and with decent travel because i hit up the trails alot
Old Feb 18, 2010 | 09:24 PM
whistle pig's Avatar
whistle pig
Hey nicholas, I had a post about 2 weeks ago inquiring about fitting the 285's with only a 2' leveling kit. Sounded like a major pain to get them to fit. Removal of the inner fender liner, rock gaurd at rear of front fender, trimming of front bumper, and posible sheet metal trimming. I'm just going to stick with the 265/75's and call it good. You could be the first to try it though!
Old Feb 19, 2010 | 12:25 AM
mprohr's Avatar
mprohr
I don't thing you'll be into the sheet metal, but you will be into the front mud flap/ splash guard big time. You may also be into the front plastic fender liner. Be a hero for everyone else and try it ...or not.
Old Feb 20, 2010 | 06:45 PM
nicholas9393
what if u get smaller rims? say for instance i get a 15in mickey thompson sidebiter would i be able to fit 33x10.5 or whatever equivelent size?
