Pshhh leaky header
Old Feb 16, 2010 | 08:59 AM
BAdassR/T's Avatar
BAdassR/T
Default Pshhh leaky header
Ok first off I did jba headers last year as many of you remember passenger side was a beoch but didn't leak.. Well over the past 2 months I heard it leaking a little and didn't really care too much just knew it was on the list to fix... Now the gasket just let go all together and sounds like a dam clunker... Air ram sells metal gaskets which says to never have a leak again.. My question is has anyone ever used any type of copper sealant to prevent leaks and would it be a good idea or forget it? I'm planing on wraping the header while it's off.. Any input would be great!
Old Feb 16, 2010 | 02:30 PM
Adams95ta's Avatar
Adams95ta
I've never had good sucess with copper or aluminum gaskets. The gasket probably blew out do to the bolts being loosened by the heat cycles of the exhaust. Get a quality stock replacement like mr gasket and use some type of split lock header bolts or stay on top of the bolts by tightening them regularly.
Old Feb 16, 2010 | 03:16 PM
BAdassR/T's Avatar
BAdassR/T
See I did do regular tightening on the bolts never had a problem til now I prob will put in some of those locking bolts tho sounds like a good idea
Old Feb 16, 2010 | 03:34 PM
dodgetrucker75's Avatar
dodgetrucker75
it doesnt sound like a very good idea but, on the race car we dont even use gaskets, just high temp permatex, and never had a problem with it, but when i had my 440 in my 75 it would blow gaskets regulary, the only cure i found for that was to stack two gaskets and solved that one.
Old Feb 16, 2010 | 03:50 PM
Moneyman19's Avatar
Moneyman19
locktite on the bolts after a gasket..maybe add 2 like dodgetrucker said??? ahhaha
Old Feb 16, 2010 | 04:09 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Everyone has heard of doubling the head gaskets, so with that said I cant imagine why it wouldnt work on the exhaust, like trucker was saying.
Old Feb 16, 2010 | 06:27 PM
BAdassR/T's Avatar
BAdassR/T
i just want to do this once more its a total B*tch to do.. doubling gaskets wouldnt be a bad idea i just want to see if anyones used these
http://www.airram.com/product.php?ca...&productid=292
Old Feb 16, 2010 | 08:27 PM
ssenay's Avatar
ssenay
A long time ago someone told me to soak the paper/felt (whatever they are) type of gaskets in water so they expand. I guess when you bolt them on they seal better. Not sure if that really works or not.
Old Feb 16, 2010 | 09:40 PM
dodgetrucker75
thoes look almost identical to the ones we use on the diesels, and work great, also if you are going to completely pull the header, put a straight edge on the flange and make sure its flat, the double gasket i was using were the grafite ones...
Old Feb 17, 2010 | 12:48 AM
superdak05's Avatar
superdak05
thats why i left the manifolds an just opened the y pipe
