Headlight / Electrical Issue
Old Feb 21, 2010 | 08:57 PM
Johna56's Avatar
Johna56
Default Headlight / Electrical Issue
Did a search - need help, please. I hope I'm overlooking something simple but I just can't figure out what's going on. I needed a driver side headlight bulb. Decided to replace both driver and passenger side this afternoon. Just the bulbs, nothing else. I went out this eve and low beam is very low, the high beam seems fractured or distorted and is not as bright as the low beam was previously, the hi beam indicator light on the dash is on regardless of the beams being on high or low (its off when the lights are off) and the fog lights turn off when I turn on the headlights. Anyone come across something like this?
Thanks.
Old Feb 21, 2010 | 09:24 PM
biker_ahoy's Avatar
biker_ahoy
What bulbs did you use to replace the burnt out one?
it should just be plug and play, I'm not sure what's going on there.
Old Feb 21, 2010 | 11:01 PM
Johna56's Avatar
Johna56
I don't remember exactly but I got them from the dealer yesterday am.
Old Feb 22, 2010 | 12:38 AM
biker_ahoy's Avatar
biker_ahoy
I would talk to the dealer, mabye try putting the old good bulb back in, just to see if it will fix the issue
Old Feb 22, 2010 | 10:44 PM
Moneyman19's Avatar
Moneyman19
you sure he didnt give u a turn single bulb? go to a napa or advance they will help u what silverstars u can put in heehh u wont be disappointed
Old Feb 24, 2010 | 01:52 AM
Johna56's Avatar
Johna56
The way they are dimmed it seems like they are just the wrong bulbs.
