180 Degree stat
Old Feb 22, 2010 | 10:02 AM
sullysdetailing's Avatar
sullysdetailing
Default 180 Degree stat
I have a 3.7L Raider. i want to get a 180 thermostat. Do the ones off the 4.7L fit if not where can I find one for the 3.7L
Old Feb 22, 2010 | 11:48 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Yes they are identical. 3.7 and 4.7
Old Feb 22, 2010 | 11:52 PM
Blown287's Avatar
Blown287
Exactly what Bolt said. I'm using a Prestone 330-180 T-stat, I recommend using a dremel to cut a small slit in it. I tried one without putting a hole in it and it broke into two pieces, lol. If you look at the stocker, it has a hole with a ball bearing sitting in it.
Old Feb 23, 2010 | 12:00 AM
sullysdetailing
Thanks Guys
