Woodgrain bezel no more!
Old Feb 28, 2010 | 01:03 AM
dakota_raven's Avatar
dakota_raven
Well done!! It looks great!!!
Old Aug 13, 2010 | 12:35 PM
tjacKz's Avatar
tjacKz
i having trouble removing the bezel from my truck itself whats the best method?
Old Aug 13, 2010 | 04:18 PM
Eimer123's Avatar
Eimer123
I am pretty sure all you do is remove the 2 or 3 screws from the bottom and carefully pull it from the bottom outwards. If I remember right there is a couple of spring pressure clips that just hold the middle in place.
Be careful not to rip the wire connections out.
I will be doing this project Sunday. and will be doing a step by step DIY
Old Aug 13, 2010 | 04:53 PM
tjacKz's Avatar
tjacKz
Please do because I need a more indepth set of instructions
Old Aug 14, 2010 | 12:34 PM
Hammond_Egger's Avatar
Hammond_Egger
Remove the 2 screws from the bottom, and then pull outward from around the AC controls. Next, pull outward by the radio. Finally, gently lift the bottom upward to remove the two tabs from the upper part of the bezel, by the AC vents.
It helps to have the Ebrake on, and to have the gear selector in the lowest position.
The Airbag light connector on the top should be disconnected first, then work your way down. Most connectors come off easy, the airbag light and the "dash" light in the center anr usually the most difficult.
Take your time, it is easy to do.
Old Aug 15, 2010 | 01:04 PM
Eimer123's Avatar
Eimer123
I started a detailed step by step
https://dodgeforum.com/forum/3rd-gen...-painting.html
Old Aug 15, 2010 | 09:32 PM
wish i saw this earlier, i want a wood grain to replace my silver one. we could have traded...haha...looks real good though and thanks for the tip about heating up the paint cans.
Old Aug 15, 2010 | 09:39 PM
Brian9's Avatar
Brian9
I didnt feel like painting mine so I just wrapped it in aluminum foil! lol just kidding I like my wood bezel...however nice write up in the other thread so far elmer
Old Aug 15, 2010 | 11:07 PM
Hammond_Egger
jkeaton, check your PM.
Old Aug 17, 2010 | 01:32 AM
italiandominator's Avatar
italiandominator
Rustoleum has a nice line of hammered metal paints, gives a nice texture look. thats what I used on mine (hammered silver) and I then misted over it with black to darken it up, after a few clear coats it came out awesome.
