I suggest the K&N Air Filter 33-2175 `05 Dakotas
Old Apr 27, 2005 | 02:21 AM
DeletedUser01's Avatar
DeletedUser01
Default I suggest the K&N Air Filter 33-2175 `05 Dakotas
I purchased the K&N Air-Filter today p/n 33-2175. I'll take some photos to compare the two filters later.
The K&N came with a stick on rubber gasket for the top half of the intake. The K&N isnt nearly as thick as the factory one.
From a dead stop the truck seemed truely more Responsive when pressing the pedal and maybe it was my ears but the exhaust and engine both sounded better the engine seemed to run better as well.
While replacing the filter today i noticed that the air-intake ran out the passenger side engine wall which i thought was nice it not getting any of the warmer air that may be out infront of the truck in summer time stop and go traffic.
No Cold/Cool Air-Intakes are out yet for the `05 dakotas and to tell ya the truth with the setup it has now seems to run just fine and it seems to be getting all the air it wants or needs not sure i'll need one other than for looks with the cone filter. Any input on this?
Catch ya's later.
Old Apr 27, 2005 | 06:02 PM
Narcisse91's Avatar
Narcisse91
Default RE: I suggest the K&N Air Filter 33-2175 `05 Dakotas
I've got a full intake on my '05, technically not a cold air intake, since the filter is a cone in the stock location, but it sounds awesome. I think the truck pulls a little harder, but who knows... It was worth it for the sound alone.
Old Apr 28, 2005 | 02:39 AM
DeletedUser01
ORIGINAL: Narcisse91
Narcisse91 I've searched the Web Up & Down,... Where did you find your setup at?
If you have the link please post it, if not what is the part number and who maked your setup?
I can then do a search on the web for it to see what i can come up with.
Thanks for stopping by.
Did you see my Step-by-Step install of the K&N Air Filter i did?
Old Apr 28, 2005 | 12:34 PM
m10rules's Avatar
m10rules
All I can say is that you are mean First the flowmasters and now the K&N.....can't wait to start tearing into mine (have other toys to spend the money on for right now...but soon!!!)
Old Apr 28, 2005 | 03:52 PM
Narcisse91's Avatar
Narcisse91
ORIGINAL: 2005 Dakota CC 4.7l
I had a full write-up on what I did over at http://www.dakotatrucks.com, but apparently they just lost a lot of threads recently, including mine.
Basically, I bought an intake from 360airintakez.com:
http://www.360airintakez.com/item--0...ge_D_47PS.html
It's meant for 00-04, but I just kinda rigged it in. The bracket didn't fit perfectly and there was no hole anywhere for the IAT sensor. So it isn't seated as nicely as you may want, and I had to make a hole for the sensor, but it is in there, and it sounds awesome. I plan to try to clean it up a bit now that it's warmer.
Old Apr 28, 2005 | 08:27 PM
Kicknzx3's Avatar
Kicknzx3
very cool, glad others noticed this. i installed the panel filter too....now all i would really like to do is get rid of the resonator and ducting but keep the stock airbox...think its a great design
Old Sep 7, 2005 | 02:23 PM
dakdeano's Avatar
dakdeano
How did the filter affect gas mileage?? What about the air intake system?? Did it get worse, better...I am considering both of these options, and am just curious
Old Sep 7, 2005 | 06:33 PM
weaponRintake's Avatar
weaponRintake
Weapon-R makes a kit for this truck, contact Leo @ weapon-R by going to www.weapon-r.com to talk about pricing.
AND
for those of you that know ... K&N has dropped a CAI for the truck as well at this time. Check out their web site.
Old Sep 8, 2005 | 05:21 PM
i11m10c2's Avatar
i11m10c2
i was looking at replacing the intake to, but box and intake is good desighn is good for cold air intake AIRAID MAKES AIRAID JR WHICH IS A PANEL FILTER AND A INTAKE TUBE THAT REPLACES FROM FILTER BOX TO INTAKE and is smooth pipe PN# 300-717 # 300-917 for durango but think it will work il keep u posted if i get it done
Old Sep 8, 2005 | 08:47 PM
i11m10c2's Avatar
i11m10c2
ok just got of phone with airaid and 2005 dodge dakota part #s are 300-175 for total intake replacement or 300-765 for the airaid jr kit with new filter ant intake tube you get to keep stock filter box.
