DIY Step-by-Step. Installing a K&N Air Filter.
Old Apr 27, 2005 | 08:20 PM
DeletedUser01's Avatar
DeletedUser01
Default DIY Step-by-Step. Installing a K&N Air Filter.
Installing a K&N Air Filter in to Your Stock 2005 Dakota & Others.
Locate your Stock Air Intake and Hoses.
Disconnect the connected Hose and Air Intake Tube.
Locate the 4 Clips that are Holding the Top of the Air Intake On and Unclip them.
With the 4 Clips Disconnected now you can remove the Top Part of the Air Intake.
Along with the K&N Air Filter came a supplied Foam/Rubber Stick on Gasket. Stick this to the Inside the of Top Part of the Air Intake.
With the Top of the Air Intake Off you can now Remove the Old Stock Air Filter and Set it aside for safe keeping.
With the Stock Filter out let's compare the 2 Air Filters. Stock Filter on Left, The K&N Filter on the Right.
Before replacing our Air Filter, Lets take a look at the Stock Air Intake and see how it works. You can see that it gets it's cooler air from outside the Engine Compartment.
Now Insert the New K&N Air Filter in to the Stock Air Box. The New K&N Air Filter should Only Fit 1 Way, See the 3 Tabs on the Filter? Those Fit in to where the Clips for the Top Part are located so this is simple.
Now you can put the Top back on making sure to push it back so that it hooks in nice and tight.
Now Connect the Hose and Tighten down the Air Tube.
Also supplied with the K&N Air Filter was a Do Not Discard Sticker. Go ahead and stick this on to your Air Box.
Now it's time to Stand Back and Look at the Job we've done together.
K&N Air Filter Box Information.
And there you have it,... A Step-by-Step on how to install a K&N Air Filter In to your Stock Dakota.
Hope this someday helps someone.
Take Care & Good Luck.
Old Apr 27, 2005 | 08:25 PM
DeletedUser01
Default RE: DIY Step-by-Step. Installing a K&N Air Filter.
This can also be found on the 2nd page of my Homepage or by ( CLICKING HERE )
Let me know what you guys think.
Have a good one.
Old Jun 16, 2005 | 02:53 PM
DeletedUser01
Oh Man,... WTF Cardomain Put their Crap Logo on my Pictures. WTF.
When the hell did that happened?
FYI. If you want to create your own website free of charge with a WYSIWYS Editor I've just added a script that will allow visitors to create their own Online Website Free.
You can pretty much design you site anyway you want to with the new editor.
Jim.
Old Sep 10, 2006 | 11:52 AM
Mantis's Avatar
Mantis
GREAT post!
Old Sep 10, 2006 | 12:36 PM
gb2's Avatar
gb2
I have an 01 5.9 magnum when I was about to change the air filter on, I noticed the top didn't look right, or seated rather. Then, OH NO !! The 4 tabs that hold the back down were broken !! So, now I need to replace it. I'm thinking the K&N, my work partner told me on his he lost 1 to 2 mpg....... Is that what you noticed ?? I got to do something soon, right now I have the Ky fix applied !!!
[IMG]local://upfiles/43588/9235C378671F47D8B7D8A2ACA87E119D.jpg[/IMG]
Old Oct 15, 2006 | 01:33 PM
Chromey's Avatar
Chromey
Nice! thank you.
Old Nov 2, 2006 | 10:36 PM
Daves05Dakota's Avatar
Daves05Dakota
LOL,... Wheres the pictures at?
Man this website blows.
D05D
Old Jan 15, 2007 | 02:04 AM
pamalsa's Avatar
pamalsa
Hi i saw your pictures on the WTF page, what company made the air intake tube, and does it comewith asensor???, can i use on the 3.7 dakota '05, and where i can get it??
i really apreciate your help, thanks
Old May 23, 2007 | 12:22 AM
lauren_24's Avatar
lauren_24
Thanks...How about for airaid air filter? I suppose that the installation is quite similar to the k&n? My sis got this airaid parts and she ask me if i can help with the installation. Anyway, your post is a great help..thanks
