Need an electric expert
Old Feb 28, 2010 | 04:04 PM
Moneyman19's Avatar
Moneyman19
Originally Posted by dodgetrucker75
here is what you should have, 4 wires on each relay, one is ground, one is power feed to the lights, one will be 12v from the battery and should be fused, and one will go to the switch, then another wirh from the switch to a power source, you can connect the wire from the switch to the relay together between both relays, all other wires should be run seperatly, but you dont need to run anyhting else on the switch circuit, the second white wire wont be used
thx man now should i just connect the second white wire to the batter and tape it off? or just hide it?
Old Feb 28, 2010 | 05:59 PM
dodgetrucker75's Avatar
dodgetrucker75
no, dont connect it at all, if you can take some pics of what you have hooked up and i can tell you exactly what you need to do with all the wire colors,
Old Mar 1, 2010 | 02:26 PM
Moneyman19's Avatar
Moneyman19
took a few pics for yea since i noticed something under the hood.
Old Mar 1, 2010 | 04:59 PM
dodgetrucker75
if you get another identical wiring/rely kit, hook everything up again just like you have it but without the white or green wires, then take the green wire that you have here in the last pic and hook it to both relays, then all lights will be controled with the one switch
Old Mar 1, 2010 | 06:01 PM
Moneyman19's Avatar
Moneyman19
Hey just real quick im in class. I came across this the one i was looking at had one remote. if i got a stronger relay when i get the new lights think I could hook up them with this plus the light i already have and still be able to use my rocker switch if i wire it correctly? if not ima just wire up the new lights to this. I cant decide on what to get was lookign to get sum kc slims but not enough room so looking at more rectangled lights like 55 watts so not gonna be atleast 100 but i can always get the bulbs at a later time. i just want them in my tow hook area to give me more of a wider angle when i have my daylighters and high beams on... sorry im a bit of a light freak eheeh
http://cgi.ebay.com/ebaymotors/REMOT...Q5fAccessories
