stereo 12v power source. where? how?
Old Mar 29, 2010 | 03:28 PM
gsxrida1980's Avatar
gsxrida1980
I think you guys are on to something. I have just been using the red wire out of the harness to grab what I believe to be switched power from the cig light. BUT I do not have a 12V constant hookup; I think I need both from what I am hearing. So, I have all the speakers hooked up with the harness red going to the cig lighter. I think I need to hook the yellow wire radio wire into a 12V source.
This leaves me with two questions; look at the pic i snapped. If I have red from harness out to cig lighter, what do i do with the yellows. One yellow comes from the harness (to 12v battery maybe)...the other from the radio - what do I do with this yellow battery wire if the yellow from the harness it out grabbing power from the battery? Had yellow from harness hooked to yellow from radio with red from harness/axxess box to cig lighter, now understanding this is wrong.
Thanks again fellas
Old Mar 29, 2010 | 03:32 PM
gsxrida1980
Eric - see the picture of the unit; it is the Metra Axxess 6502 interface. I am thinking my constant to the battery is the issue here...ie no hooked up at all. Now if I can only know a simple way to run this wire to my battery and the correct place to hook it up to, I will hopefully be on my way..
File Type: jpg
Old Mar 29, 2010 | 04:56 PM
gsxrida1980
Should I run the yellow from the radio to the battery? What about the yellow coming from the harness? what does that hook into? Many Thanks
Old Mar 29, 2010 | 11:25 PM
gsxrida1980
We have liftoff! I feel like tim bleepin allen from tool time - the guy that creates hazards and blows things up but gets the job done. the stereo is hooked up and working beautifully. Hit the battery (like you told me), hit the cig light with red switched (like you told me) and success! Just need to make the perm battery connection through the dash, assemble and done...wait...my Alpine 6.5s are going in next. Maybe tonight! Then this thing will thump. Many thanks to all and will post up pics ASAP. Gotta think about the next project - maybe performance to pep up the 4.7L. Pete
Old Aug 26, 2010 | 01:58 AM
wadibartolo's Avatar
wadibartolo
Default results?
Pete,
I am planning on installing a JVC head into an 2005 dakota quad cab with basic (not premium) factory sound. I purchased the Axxess harness; it looks like the same one you have.
However, I am having trouble following your last post; can you let me know if I am following your install correctly?
1. connect grounds.
2. connect 8 speaker wires together (greens, grays, purples and whites).
3. connect red from axxess box to cig. lighter.
4. connect orange stripe from axxess box to red on jvc harness.
5. connect yellows
6. connect orange from axxess to orange stripe on jvc. (is this the dimmer?)
7. do not connect blue wires.
You said in your last post that you ran the yellow to the battery. which yellow was that, from the axxess harness or the jvc? what did you do with the other yellow?
Thanks,
Bill
Old Aug 26, 2010 | 03:06 PM
mprohr's Avatar
mprohr
Your red switched source was the main problem. You have to go to the cig lighter for that, it will not work from the harness. The yellow contant source from the harness is just fine.
Old Aug 27, 2010 | 04:58 PM
wadibartolo
Default I still need help
Thanks, but i'm still not sure of what exactly I should be doing so I attached a photo, hopefully this helps.
I made all my speaker connections, yellow and black.
Which red should go to the power source, (A) to/from the JVC head or (B) from the Axxess adapter? (A and B are labeled in the photo)
Also, I understand why I don't want to get involved with the dimmer, but what's the deal with the extra orange coming out of the harness that comes from the dodge? (D in the photo)
Thanks,
Bill
File Type: jpg
