CAI DIYrs, what size did you use?
Old Apr 26, 2010 | 01:13 PM
00dakSport's Avatar
00dakSport
I used 3" schedule 40 pvc. then i put to coats of flat black primer.
what kind of paint did you use? u think ceramic header coating would work?
Old Apr 27, 2010 | 10:44 AM
blakdak07's Avatar
blakdak07
That sounds like a good idea, if it will stick.
Old Apr 27, 2010 | 12:18 PM
canadian dakota's Avatar
canadian dakota
Originally Posted by babygotdak
I also heard that when PVC heats up it can give off vapors that aluminum heads don't get along with.
never heard that what it do to the heads
Old Apr 27, 2010 | 02:20 PM
trucky's Avatar
trucky
I don't know exactly but I have heard that PVC is not good. Not only the vapor that could potentially go into your engine (not being pure oxygen isn't good) but also the same problem K&N had with residue coming off the interior of the pipe. There are other ways to make a home brew kit without PVC. But again, that would be after a long exposure to high heat and over the course of several years.
