bad call from the shop
Old Apr 29, 2010 | 11:20 AM
paul05dak's Avatar
paul05dak
Default bad call from the shop
I am getting the truck ready for towing this summer and knew I needed brake work. So brought it to the shop I use for non warrenty things and I trust last night. Got a call this morning and they told me the following. Need brake pads and roters (thought I would with how it was stopping) here is where I was "supprised" Both outer tie rods need to be replaced, too much play in them. Transfer case and back pinion seal are leaking. SO I called a dealership to find out about warrenty coverage. Being a 05 with only 26,009 miles, they said the transfer and pinion would be covered but the tie rods are not. So I called back my shop and am having them add the tie rods to the repair list.
Now, I have a SC programmer and will put it back into stock mode when I get the truck back before I bring it to the dealer (it's in milage X now). Is there any way they can claim that this is the cause of the transfer case and pinion and not honor the warrenty???
Old Apr 29, 2010 | 12:41 PM
popsnbeer's Avatar
popsnbeer
A tune would not affect your transfer case or rear pinion...so i would say no. If you have it in stock mode and bring it in, I doubt they will even know/care to look.
Old Apr 29, 2010 | 02:03 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
The tuner really has nothing to do with it. If it were me, I would put it back to stock anyway, just to be safe.
But, your describing a pretty common problem with these trucks. My rear pinion seal began its slow leak at 34,000 miles, and was replaced under warranty in 30 minutes. Hasn't leaked yet and I am at 50k, but I would expect it to be leaking again at 70k since the first one went so fast!
The tie rod ends are junk. MOOG are the ones too buy, so if its not being covered, see if your shop will replace the ends with MOOG parts, and not the lower costing OE replacements made by some 3rd party company in china. As things start needing replacement on the front end, think MOOG.
Old Apr 29, 2010 | 04:59 PM
popsnbeer's Avatar
popsnbeer
Monkey - I am planning on replacing my tie rods here in the next few weeks. Do you have a direct link or part # for the ones you would recommend. I ask you, only because I know you have had a ton of front end problems and figure that you have already tried what does, and does not, work :-)
thx
Old Apr 29, 2010 | 10:52 PM
trucky's Avatar
trucky
Listen, transfer cases leak after a few years... it's VERY normal. It's part of having a 4x4 truck. Don't think it was some outside cause....it happens eventually.
Old Apr 30, 2010 | 12:49 AM
mprohr's Avatar
mprohr
Nothing should ever break on my truck...ever....even when I am completely abusing it
Old Apr 30, 2010 | 12:50 AM
mprohr's Avatar
mprohr
I would put it back to stock. Don't give them a reason to weasle.
Old Apr 30, 2010 | 11:34 AM
paul05dak's Avatar
paul05dak
thanks. it is back to stock. mixed emotions on driving it now, it is riding really good and turning/brakeing better than I can remember, but the stock tune is *******. Even in the Mileage X tune it is so much better than stock. Can't wait till I get the warenty work done adn put it back. May need to run in 91 octane for a while just to make me feel better!
Old Apr 30, 2010 | 10:49 PM
whistle pig's Avatar
whistle pig
Wow Paul. I thought i was the oldest lowest mileage 05 Dak on here. I bought it 9 months ago with 21K on it. I have 30K on it now. Nice having the 7 yr. 70K warranty.
Old May 1, 2010 | 06:02 PM
paul05dak's Avatar
paul05dak
Whistle pig, We have 3 vehicles, Wifes DD is a 07 prius with 80,000 plus. I also have a 05 grand caravan with 38,000 on it. I would say I drive the truck the most but I really don't have a commute for work. I work from home. It's nice having the 2 dodges with low mileage and 05's. Should last a while. AND all 3 are paid off, no car payments.
