new component system
Old Apr 29, 2010 | 05:00 PM
forestwcat58's Avatar
forestwcat58
Default new component system
which should i get
http://www.crutchfield.com/p_130TSA1...2C.html?tp=106
or
http://www.crutchfield.com/p_107DB65...01.html?tp=106
one is bigger but one has better frequency. which one?
Old Apr 29, 2010 | 06:52 PM
ariese's Avatar
ariese
polk audios better then pioneer in my opinion
Old Apr 29, 2010 | 07:59 PM
MrCrash's Avatar
MrCrash
Polk FTW. Bigger woofer, better tweeter (I've always heard silk tweeters were better), better low range frequency, higher power handling capacity, and higher sensitivity (will be louder for a given amount of power).
Don't worry about the upper frequency range unless you want your dog to enjoy music you will never hear, since humans can only hear up to around the 20kHz range at best
Old Apr 30, 2010 | 12:56 AM
mprohr's Avatar
mprohr
Do you have the factory Alpine speakers? If you do, you're in luck. You will not find many better speakers out there.
Old Apr 30, 2010 | 12:52 PM
mprohr's Avatar
mprohr
The paper cones are light and accurate. If you are not looking to shatter your eardrums, they are a great choice. I have had two sets of quality poly-coned speakers, and the Alpines are much better. I have 75watts per speaker x-over at 90 hertz.
Old Apr 30, 2010 | 07:53 PM
mprohr's Avatar
mprohr
Yes, I'm comparing them by ear. My entire life has been car audio, custom home theater, and now pro-sound. My ear is pretty good, and I don't need an RTA to tell me what works. Many of the best speakers have paper cones. In the case of the Alpines, paper cones with butyl rubber surrounds, injection molded nylon baskets, 1.50" voice coils, and vented poles. All I'm saying is if you have them, you should spend your audio upgrade dollars somewhere else first, as you will end up paying several hundred dollars for a component set that does as good a job. Heck, even the tweeters are 1" silk domes under that gray plastic.
