Dumb question bout K&N
Old May 1, 2010 | 01:48 PM
canadian dakota's Avatar
canadian dakota
Default Dumb question bout K&N
any one else out there thats running the K&N panel or cone filter have the problem with running outta the cleaner before the oil i have four cans of the oil and no cleaner i know they say not to use any thing else..... is this just a marketing gimic will any degreaser work or is there something special bout the K&N stuff ?????????
Old May 1, 2010 | 04:29 PM
Altair's Avatar
Altair
Dak attack!
Haven't had that problem yet but I've only cleaned it once since installing it, probably due for another cleaning. I would expect you to run through cleaner faster, you don't need a lot of oil to re-oil it.
Old May 1, 2010 | 04:53 PM
canadian dakota
yep definatly go through the cleaner faster and you can't seem to by just the cleaner and I really don't feel like buying another box when I got two full and two half cans of the oil
Old May 2, 2010 | 08:06 AM
superdak05's Avatar
superdak05
i have 2 cones and dont use the cleaner that often, i just soak the filter in luke warm water over nigh to loosen up the crap, than take the spicket from the kitchen sink and spray from the inside out, works just as good,
Old May 2, 2010 | 08:32 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Havent run into the problem yet, but I would agree that it wwould happen
Old May 2, 2010 | 01:49 PM
canadian dakota
I just went out and bought a new recharge kit I only got one cone so ima hafta install the stock box for now
Old May 2, 2010 | 02:22 PM
Mahadigus's Avatar
Mahadigus
I know that you can get the oil in a bigger can at napa and Mopac so they probably have the cleaner sold the same way
Old May 2, 2010 | 02:37 PM
canadian dakota
good to know now thanks lol lost your number dude you ever get that charger installed
Old May 2, 2010 | 03:48 PM
JAB02LHS's Avatar
JAB02LHS
http://www.knfilters.com/clningacc.htm
Old May 2, 2010 | 03:50 PM
JAB02LHS's Avatar
JAB02LHS
You may never need to clean it
Originally Posted by K & N FAQ
4. How often do I need to clean my K&N air filter?
If you have not experienced a decrease in mileage or engine performance, chances are your filter is fine and does not yet need cleaning. To be more specific, the filter does not require cleaning if you can still see the wire screen on the entire air filter regardless of how dirty it may appear. When the screen is no longer visible some place on the filter, it is time to clean it. When used in normal paved road, street or highway conditions, our replacement air filters that fit in the factory air box should require cleaning every 50,000 miles and our large conical filters on an intake system should require cleaning every 100,000 miles. When used in dusty or off-road environments, our filters will require cleaning more often. We recommend that you visually inspect your filter once every 25,000 miles to determine if the screen is still visible
