Negative camber after leveling kit
I notice a pretty good amount a negative camber after installing a 2.5" leveling kit. It's to much for an alignment to correct. The only thing I see that will correct this is a longer or adjustable upper control arm. I've heard of camber kits but never seen one for a dakota. Any ideas?
I put the 2 1\2 leveling kit on my 06 and after an alignment it was perfect. shop said it was close but was able to get it aligned without any camber kit. so unless you were already bent or out of alignment you should be good.
