2006 Dakota Transmissions
Old May 17, 2010 | 07:47 PM
Joeag40's Avatar
Joeag40
Default 2006 Dakota Transmissions
My tranmission does not kick in for a few seconds when first starting the truck and shifting into gear. This is only happening when first started after a long period of time.
What type problem may this be?
Thanks
Old May 17, 2010 | 10:17 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I will move this to the 3rd Generation Dakota sub-forum.
Old May 17, 2010 | 11:51 PM
projektdirtfab's Avatar
projektdirtfab
fluid and filter change recently???
install the filter gasket with a mopar punch? fluid level correct? our trans are really picky.
Old May 18, 2010 | 10:22 AM
sullysdetailing's Avatar
sullysdetailing
I had the problem after adding 32'' tires on my 3.7L I added a B&M Tranny Cooler and it helped out alot.
Old Jul 31, 2010 | 04:08 PM
yttaf's Avatar
yttaf
I have this problem too! It started after I changed my tranny fluids & filters! I switched to synthetic ATF+4... now I just wait a minute then put it into reverse
Old Jul 31, 2010 | 10:08 PM
sparks1032's Avatar
sparks1032
Not sure if I got the TSB my dealer sucks and sure did not look into it. I just wait a few minutes for the truck to warm up and don't have the problem. If you get in and try and go right away the lag is HUGE so start with the dealer and the TSB then
join the club of SLOW shifters
