Help with Amp and Subwoofer connections
Old Jul 31, 2010 | 09:14 PM
Adams95ta's Avatar
Adams95ta
Default Help with Amp and Subwoofer connections
I have the stock headunit and speakers and I'm trying to install an amp and subwoofer. Where is the stock amp at? Where are my hookups for the audio input and remote power turn on?
Old Jul 31, 2010 | 10:34 PM
If you are asking where the stock amp is, I assume you have the Infinity sound system. The amp is located under the rear drivers side seat on the quad cab. There is another post on here about someone trying to install an aftermarket amp. Not sure if an aftermarket amp is plug and play.
Old Jul 31, 2010 | 11:36 PM
lootownpunx's Avatar
lootownpunx
might not have rca's on the stock head unit or remote wire....you couldddddddd
set up highpower to and amp tho.
-find a switched power wire for your amp(for when you turn key on sends 12v)
-wire a jumper before a main speaker wire to your amp's input(acts as the rca's would)
all amps can be differnt tho...may not all work
i sugest not doing it tho....much easier to buy an aftermarket head unit for heck 85 at wallymart? lol
gets rid of the hassel and the risk of messing things up like spiking your altinator or somthing
Old Jul 31, 2010 | 11:50 PM
Adams95ta's Avatar
Adams95ta
I did a little more research and found this post: https://dodgeforum.com/forum/683201-post4.html
Old Jul 31, 2010 | 11:59 PM
lootownpunx
it can be done
i was going of memory we did it back in highschool 7 years ago with little money lol
good find adams
