fuel filler problem i think
Old May 22, 2010 | 03:21 PM
canadian dakota's Avatar
canadian dakota
Default fuel filler problem i think
has any one else expirenced an issue when filling up theyre truck with gas. that it will take a couple litres/gallons then shut off i tried a different station thinking it was the pump..... still does it i checked the lines from what i can see nothing looks kinked, truck runs fine but it took me almost a half hour to fill my tank from empty
Old May 22, 2010 | 03:49 PM
utahdakota's Avatar
utahdakota
Yup, i've had that issue, so far it looks like it was just that pump, simple as going to the station across the street and the problem was solved
Old May 22, 2010 | 04:02 PM
canadian dakota
Originally Posted by canadian dakota
has i tried a different station thinking it was the pump..... still does it i checked the lines from what i can see nothing looks kinked, truck runs fine but it took me almost a half hour to fill my tank from empty
lol thanks though
Old May 22, 2010 | 04:16 PM
utahdakota's Avatar
utahdakota
ha, totally misread your first post wrong, aint i just a huge help :P
Old May 22, 2010 | 05:15 PM
canadian dakota
haha no problem dude thanks for coming out though lol
Old May 22, 2010 | 07:43 PM
popsnbeer's Avatar
popsnbeer
I have had a similar problem. I have found that not putting in the handle all the way (leave it hanging a little bit more) can solve the issue. I think it's just the angle of some of the handles and the filler neck takes a little longer to get the gas into the tank and therefore shuts off the handle due to a backup.
Old May 22, 2010 | 07:45 PM
canadian dakota
tried that even with just the tip barely in still kept coming up and clicking of I've used these stations before
Old May 28, 2010 | 01:33 AM
canadian dakota
Bump****** so i downloaded the manuel a few months back and seemed to of lost it on my comp but quic question is there a breather valve in the tank somewhere that may be plugged
Old May 28, 2010 | 01:47 AM
dodgetrucker75's Avatar
dodgetrucker75
i think there may be some kind of a valve on the fill vent, everytime mine is full and clicks the handel, the fuel is right at the top of the neck with out toping off, so it must shut off venting at some point to keep from overfilling the tank, maby that got stuck on you?
Old May 28, 2010 | 02:02 AM
canadian dakota
hmmm maybe thats why i was trying to find the manuel see if there is something in there about but yeah i noticed befor it wouldshut off at the top of the neck to.... this being said the first bit will take about 6 bucks then it only takes a buck or two i can watch it drain down the neck......
