Performance Upgrades
Old May 27, 2010 | 10:23 PM
sdtalon's Avatar
sdtalon
Default Performance Upgrades
I'm sure there are bits and pieces of these all over the board, but lets get them in one spot. I'm trying to get some more power out of my 4.7. I'd like some help with options.
Here's what I have: Intake, cat back, fastman tb, superchip, e-fan.
I'm looking at getting the H/O cams and intake manifold. Is there a better place to get those other than the dealer? And will the tb bolt right up? (no adapter or anything) I'm also looking at the asp underdrive pulley.
Any other easy upgrades?
Old May 27, 2010 | 10:29 PM
rengnath's Avatar
rengnath
If youre doing cams youll have to ditch the superchips and get an SCT with a custom tune.
You can get the HO Cams from www.airram.com for $399.
If youre asking if your fastman will bolt right up, it should. 3 bolts to remove the old, change out the sensors and bolt the new one on.
One upgrade I would look at doing if I had the money would be the 2008+ intake manifold. Its also on airram.com .... but its too pricey for me.
Old May 27, 2010 | 10:40 PM
sdtalon's Avatar
sdtalon
looks like you need the adapter plate ($300 (more than the intake manifold ($250))) to make the tb work.
Old May 27, 2010 | 10:44 PM
rengnath's Avatar
rengnath
Thats why it was too much for me. Its supposed to flow much better than our 05-07 manifolds though. If anything sell your fastman (Youll get close to what you paid for it) and get a 2008 TB with the 2008 manifold. But youll probably want that SCT to tune for the added flow.
Old May 27, 2010 | 10:47 PM
lmrjason's Avatar
lmrjason
didnt realize you couldnt run h.o. cams with superchips
Old May 27, 2010 | 10:48 PM
sdtalon's Avatar
sdtalon
i havent heard the h/o valve springs being necessary in other posts, but airram makes it look like you need them for the h/o cams.
Old May 27, 2010 | 10:51 PM
rengnath's Avatar
rengnath
The cams will work just fine with a superchips tune or no tune at all, you just wont actually gain the HP until you have a custom tune. Atleast thats what they say.
sdtalon, I thought it said it recommends you change your worn ones. Airram is definetly the guy to go to for 4.7 performance though. His 4.7 ram is FAST.
Old May 28, 2010 | 01:20 AM
dodgetrucker75's Avatar
dodgetrucker75
the 08+ engines are "drive by wire" so you would have to run the adapter for your TB, i dont think there is anyway around it for now, but for $300 thats one more thing i might look into making, for less $$$ of coarse
Old May 28, 2010 | 11:54 AM
hendrixx324's Avatar
hendrixx324
I think my next upgrade is going to be E-Fan and gears in the next 3 weeks. Then ill look into HO cams
