ok so i got little bit of a problem
Old Jun 2, 2010 | 08:41 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Originally Posted by hendrixx324
ok thank you and i allways heard that its easier just tp replace the whole axle rather than just the boot
Nah boots are like 25 bucks or less and the boot guns can be rented. It takes more time getting the axle off the hub then it does putting a new boot with grease on.
Old Jun 2, 2010 | 10:18 AM
rengnath's Avatar
rengnath
If your boot got torn and the grease inside became contaminated it is. If stuff gets inside the cv shaft, it will cause wear on the parts and if you want to just replace the boot, you have to strip the cv shaft and completly clean everything off before putting a new boot on and filling it with grease. If you catch a torn boot right away though, then thats all you need to replace.
Old Jun 2, 2010 | 10:47 AM
hendrixx324's Avatar
hendrixx324
yea it was torn for a while. I dont know if you guys remember me posting somthing about it a month or 2 ago. but the new ones in and with that and the ball joint replaced my ride is so much smoother.
Old Jun 3, 2010 | 09:23 PM
Dakkkota's Avatar
Dakkkota
i did the same!
