ok so i got little bit of a problem
Old Jun 1, 2010 | 11:27 AM
hendrixx324's Avatar
hendrixx324
Exclamation ok so i got little bit of a problem
so i was changing my ball joint Saturday and i broke my cv shaft. So i bought a new cv shaft and i cant get it all the way on... it stops at about half way. I push and push and push but it doesnt budge. I compared the splines and they were the same. There is this seal, well it looks just like an o-ring on there that i think might be stopping me from putting it all the way on. Can anyone help me??
Thanks
Old Jun 1, 2010 | 12:37 PM
canadian dakota's Avatar
canadian dakota
my first guess is you haven't lined up the splines properly
Old Jun 1, 2010 | 01:30 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
or you are backwards...
Old Jun 1, 2010 | 01:52 PM
dodgetrucker75's Avatar
dodgetrucker75
the o-ring you are talking about, is it steel? that may be the retaining clip and some times they need quite a bit of force to seat them, a rubber hammer normally works quite well, or a block of wood, to give it a little nudge in, how did your c/v break? i pulled mine apart a couple times, but a little playen around with it, got it to slide all back together again
Old Jun 1, 2010 | 02:41 PM
hendrixx324
well it had a torn boot... but it like was literaly hanging from the boot. It wasnt connected at the top pivot point. do you know what i meen? and its a rubber o ring
Old Jun 1, 2010 | 03:13 PM
dodgetrucker75
yep thats what happens when they are pulled to far, but its not broke, you can slide it back together again, just a matter of aligning the joint, and they do make replacement boots too, but for your install, try to give it a nudge with something that wont damage it and it will probably pop right in, there is a retaning clip in there somewhere that you have to over come to get it to lock in fully
Old Jun 1, 2010 | 08:30 PM
hendrixx324
ok thank you and i allways heard that its easier just tp replace the whole axle rather than just the boot
Old Jun 1, 2010 | 11:41 PM
hendrixx324
update: all fixed. I just gave it a few love taps and some verbal persuasion and it went right in.
Old Jun 1, 2010 | 11:44 PM
canadian dakota
lol nothing like talking sweet love to your ride when she's being a stubborn ****
Old Jun 1, 2010 | 11:48 PM
hendrixx324
HAHAH exactly....Sometimes you just gata show her whos boss!
