guttur guard grilles?
Hey guys im thinking about doing the gutter guard grille this weekend and was wondering if any of you guys have done it and if so do you have pics of the inside for me?
thanks in advanced
thanks in advanced
Guest
Posts: n/a
its really quite easy. just fold the extra mesh over and plastic weld them in place. just keep cutting relief cuts to make the front smooth... here is how mine turned out.
I used these little puppies...
this is what I ended up with after about 40 minutes of working on it.
I ended up painting it black.
I used 3 pieces of gutter guard, since I messed up a cut on one of them... but 2 would probably do it.
They are /were $1.94 when i got them.
I did the same thing a few years ago in the gills of on my Corvette, the panels where the gills are come off and I used double sided tape on the inside of the panel then put another layer of tape over top of it and it hasnt budged in over 3 years....but would recommend something stronger then double sided tape and use something like Eric suggested for your project since the grill on the truck is getting pushed on alot harder by the wind. I like the look and have gotten alot of positive comments about it from other Corvette owners. The best part is it didnt cost alot of money or alot of time.
yeah i know that it comes out... i was thinking about taking it out and cutting the fins out of the middle (leaving a frame that still attatches to the grill) and sandwiching the grill between that and the chrome part
Trending Topics
If you dont want to do a cutout for the hood release latch, just tie a piece of wire or use a wire hanger and run it down the center of the grill to a loop that can be reached between the grille and the bumper. If you need pictures of mine LMK. It sometimes gets a little tricky to get the hood open, but once you fine the loop with your finger it just needs a little pull.
Thats a good looking grille you made Eric. Is that gutter guard stuff stainless?
