Heater Hoses
Old Jun 25, 2010 | 12:32 AM
pojv's Avatar
pojv
Default Heater Hoses
Has anyone replaced their heater hoses on the 05 4.7?
If so where did you get the hoses as I can only seam to find them at the dealer?
Thank you
Phil
Old Jun 25, 2010 | 11:18 AM
eBay. Search for "Dodge Dakota Heater Hose". I saw a few on there.
http://cgi.ebay.com/ebaymotors/Dayco...Q5fAccessories
Old Jun 25, 2010 | 01:54 PM
pojv's Avatar
pojv
Thank you for the link but those are not the correct heater hoses, as the ones on the truck are a rubber hose coming from the engine then crimped into a metal pipe running across the engine then crimped back to rubber hose.
Phil
Old Jun 25, 2010 | 09:46 PM
oooohhhh....those hoses.....my bad....i'm striking out on that too....could you use generic hose of the same ID and clamp it to the pipes?
Old Jun 26, 2010 | 12:23 AM
Blown287's Avatar
Blown287
When I installed the blower I had to remove the OEM rubber to medal. I just bought standard radiator hose at NAPA and ran it behind the block.
