Tranny fluid change question
Old Jun 28, 2010 | 09:10 PM
phil74501's Avatar
phil74501
Default Tranny fluid change question
My truck has just under 90,000 on it. I've never changed the transmission fluid. I know I should've gotten it done at 60,000, but never did. I went to my usual oil change place to get it done. They told me they don't do those anymore, and pointed me to another place. But, the guy that runs the oil change place told me if you don't get it changed at the intervals in the manual, it's best not to get it changed at all. I was told by a friend that his mechanic told him the same thing. Anybody ever heard this before? Should I get it changed? Or just let it go?
Old Jun 28, 2010 | 09:16 PM
damyankee84's Avatar
damyankee84
They are kinda correct. You can do a filter and fluid change anytime but they dont recommend a flush if you've never done anything with it. If you've never flushed it then you run the risk of breaking loose buildup that might be hanging around and causing either damage or leaks. But just changing the filter and fluid wont hurt anything.
Old Jun 28, 2010 | 09:53 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
I agree... I would leave it alone, just change the oil and filter.
Old Jun 28, 2010 | 09:57 PM
06HEMI4X4's Avatar
06HEMI4X4
as long as the trans isnt slipping and the fluid dsoesnt smell burnt, a shop that sells BG products will do it and BG will warranty the trans
Old Jun 29, 2010 | 07:00 PM
phil74501's Avatar
phil74501
The transmission is running fine. No slipping. Just want to make sure it doesn't take a dump on me anytime soon. So just get the fluid changed and that's it?
Old Jul 1, 2010 | 08:35 PM
tnyknz's Avatar
tnyknz
I just changed mine on my '07 3.7L. It had around 125,000km on it and I just thought it was about time to change it, it's really hard to find the old cork gaskets, so I just used some black gasket goop stuff. Also finding the quantities for the automatic transmission was frustrating, but it's 4-5 quarts. I overfilled mine and had to siphon some out with a hose down the dipstick tube.
Old Jul 2, 2010 | 08:35 AM
06HEMI4X4's Avatar
06HEMI4X4
with the BG flush you dont even need to change the filter, Just flush and your done. We have been doing this service in my shop for years, at a rate of about 8 flushes a week and I can only recall 1 issue after service. Which probably had nothing to do with flushing, would have happened anyway. As far as the filter goes most trans dont have a filter anymore its just a screen, kind of like oil pick up but finer
Old Jul 2, 2010 | 09:23 AM
I've had two trucks (a ford and a chevy) that within a few thousand miles after having the tranny fluid changed and filter replaced, the transmissions went out. Coincidence? Now I'm afraid to have the fluid/filter changed lol.
Old Jul 2, 2010 | 10:32 AM
06HEMI4X4's Avatar
06HEMI4X4
all I can tell you is what ive experienced. you really need to be sure that the fluid isnt burnt or sliping, no flares ect, use the right fluid with the right additives.
Old Jul 2, 2010 | 10:57 AM
superdak05's Avatar
superdak05
i go every 30000 miles on my 2005 dakota, dealership drops the pan, new filters and gasket, all for 119.00, well worth it. forget those oil change shops, get it done correctly
