Hot Air Problem
Old Jul 3, 2010 | 02:23 PM
forestwcat58's Avatar
forestwcat58
Default Hot Air Problem
So I left a party a couple of nights ago and was halfway through m 1 drive back home at 10:30 when I hear a click when I turn the air halfway up. So I get warm and put it back all the way cold but it still blows hot air. So now no matter where I have the gauge it is always so degree of hot. What do I do and what happened?
Old Jul 3, 2010 | 03:27 PM
dakota_raven's Avatar
dakota_raven
check your switch dials. maybe the one that controls the temperature went bad!
Blown287's Avatar
Blown287
Find an A/C low pressure gauge and test it. Your low pressure port is by your condesnor. Start the truck, let the engine warm up and put the A/C on high max and check it. If its low, add more. If you have a leak in the system and the pressure drops low enough the compressor will not engage.
Old Jul 3, 2010 | 03:30 PM
forestwcat58
I ran the engine and the pipe for cold was freezing to the touch and had water all over it so it's not a leak and there wasnt any oil on the pipes from inside lube leaking out. And I can make it hot and then heat it up to burning so does that rule out a bad switch?
Old Jul 3, 2010 | 04:04 PM
Cuban11182's Avatar
Cuban11182
If you are saying that your ac lines are cold and that the ac compressor is on, i would say the mechanism inside the duct that changes from hot to cold is the culprit.
Old Jul 3, 2010 | 10:58 PM
forestwcat58
Thanks guys now the we have diagnosed that it is the switch how do I get the plate off to fix the problem?
Old Jul 8, 2010 | 03:20 PM
forestwcat58
I took out the dash part that covers the a/c and radio. Then I took the a/c part out and fiddled with it a little but could get it open with breaking it so I put it back and my a/c works again. Yay!
