Cranking Issue
Old Jul 28, 2010 | 04:10 PM
looks like just the insulation is torn. Wire is still good or was it shorting out? Does not look burned.....
Old Jul 28, 2010 | 04:50 PM
wolfman7207's Avatar
wolfman7207
Insulation torn on two wires. No burn marks but it wasn't starting so I cleaned and stripped the wires and patched them. Cranked right up.
Old Jul 28, 2010 | 06:38 PM
rengnath's Avatar
rengnath
Glad you fixed it man!
Old Jul 28, 2010 | 07:08 PM
canadian dakota's Avatar
canadian dakota
looks like you found the problem I was gonna say I had a similar problem back in the early summer. I had to replace the battery my cold crank amps where shot truck wanned to start but would not.. had to run the key a few times
Old Jul 28, 2010 | 07:54 PM
wolfman7207
Yeh glad I fixed it too. First truck I have had since 1997. I have always worked 50+ miles from my home so couldnt afford the gas on a truck and I finally moved a mile from my current job! Besides the starting issue the truck has been fantastic. Already modded my intake, resonator delete (sounds awesome with the stock muffler) and have done a IAT relocate.
Old Jul 29, 2010 | 12:38 PM
rengnath's Avatar
rengnath
Stick around here for sure. Someone is always doing something unique with their truck that helps us all out. You need a Superchips Tuner now
Old Jul 29, 2010 | 04:26 PM
wolfman7207
Yeh thats on my Xmas list lol
Old Aug 4, 2010 | 06:26 PM
wolfman7207
Wasnt the wiring. Happened again today near a pep boys so I took the battery out and had it tested. Battery failed immediately when they put a load on it. So bought a new battery and that has seemed to fix the issue but who knows
Old Aug 5, 2010 | 04:58 PM
wolfman7207
Well looks like it was the battery all along. Drove it around for about 45 minutes today and even sat in some stop and go traffic. Ever time it started up fine.
Old Aug 5, 2010 | 05:02 PM
rengnath's Avatar
rengnath
Atleast you shouldnt have any more problems with it. A bad battery can cause some real problems even if it starts your truck. They eat alternators for breakfast.
