Cranking Issue
Old Jul 26, 2010 | 05:53 PM
wolfman7207's Avatar
wolfman7207
Default Cranking Issue
Bought a 2007 Quad Cab SLT two weeks back. It runs great for the most part except for a small issue. If I drive it around for more than 30 or 40 miles it will sometimes have trouble cranking. I will turn the key and can hear the relays firing but wont start. Tried swapping out the starter relays but still has the same issue. Sometimes swapping the relays works and other times if I just leave it alone for about 5 to 10 minutes it works. Not sure where to start on this. Could it be a starter thats sticking?
Old Jul 26, 2010 | 06:05 PM
dodgetrucker75's Avatar
dodgetrucker75
starters that are going bad can be heat sensitive, only wanting to work when cooled
Old Jul 26, 2010 | 06:15 PM
rengnath's Avatar
rengnath
My guess would be the starter, but also check for faulty wiring at the battery and to the ground or at the starter. Even though the relays are clicking and getting power, if you have a faulty ground or connections somewhere, if the connection cant conduct enough current, it wont turn the starter.
Old Jul 26, 2010 | 06:17 PM
dodgetrucker75
great point! yep electrical connections can be heat sensitive too
Old Jul 26, 2010 | 06:24 PM
wolfman7207
Will check the wiring tomorrow. If it is the starter is that something that I can rebuild?
Old Jul 26, 2010 | 06:28 PM
dodgetrucker75
im sure you can if you can find the parts, but will brobably be a lot less of a headache to get a complete one
Old Jul 26, 2010 | 06:37 PM
rengnath's Avatar
rengnath
Yeah, a new starter is only $75 from autozone and it comes with a lifetime warranty. After you get all the parts, and invest all your time in it, it would probably be cheaper just to get a new one. Plus, if it fails then all you have to do is go exchange it. My .02
Old Jul 26, 2010 | 06:53 PM
wolfman7207
Hmmmm cheapeast I can find new for the 07 is $180. Found a used parts shop that is selling them for $30 with a 6 month guarantee. Might just pick up a used one. Thanks for the advice guys.
Old Jul 28, 2010 | 03:48 PM
wolfman7207
Well the starter solenoid was not receiving power, so I removed the fuse box and flipped it over and low and behold found this.
File Type: jpg
