Rear diff?
lol i see this forum is really like a highschool convo...lol good stuff good to read and laugh! i had that same problem with my rear diff...but it happened at like 30...and i changed to royal purple fluid and been fine ever since! the only thing i did was take the diff cover off and use the dodge RED LUBE stuff on it after i sanded off the old stuff and cleaned up the inside off the diff with break cleaner spray and used that on the diff before applying the lube. when applying the sealant as i call it go straight over the nut holes not around...makes a better seal...well atleast mine did, cause when i cleaned it i saw they had went around the outside not across. But now no leakes nothing to complain about!
