Rear diff?
Old Aug 1, 2010 | 09:45 AM
CrewKota's Avatar
CrewKota
Angry Rear diff?
While changing my oil for the first time I saw that my rear diff was leaking.
It is leaking from the pinion seal. What do I need other than the pinion seal to do this job? I know on a GM I would need a new nut and crush collor. Also what are you guys using for diff fluid?
Is this normal for an 05 with only 30k. I hope it is a resault of the truck sitting in a garage for two years before I got it, and not just a dodge problem.
By the way Dodge did a great job on the oil drain plug location!!!!
Thanks
Old Aug 1, 2010 | 12:46 PM
Blown287's Avatar
Blown287
I use Mobil 1 SAE 75W-140 synthetic gear fluid since I swithced to 4.10 gears. No leaks so far and I'm over 100k.
Old Aug 2, 2010 | 10:16 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Originally Posted by ericemery
Yeah, that darn drain plug covers my floor every oil change... stupid cross member.
Not sure on the diff problem, I have over 90k on mine and I haven't had any leak issues. I went with redline in my last gear change... almost time to do them again.
I have my Fumoto ordered...
Old Aug 2, 2010 | 10:29 AM
rengnath's Avatar
rengnath
I wonder if the guy who designed that is sitting somewhere right now, reading on all the boards of Dakota owners who complain about this and is laughing to himself for being such a genious.
If they put a drain plug for something like a transmission, coolant system, or something like that it wouldnt be bad because you dont service them often. But you are supposed to be changing your oil every 3-5k, and thats where they decide to put the plug. Not to mention, oil makes a mess the way it is.
Old Aug 2, 2010 | 06:15 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
Mine was leaking at the pinion seal at 35,000 miles. It was repaired under warranty, but I have been keeping my eye on it since.
As far as the oil thing goes...the V8 guys got screwed there, the V6 guys have the drain plug free and clear, and we also have a cool little slide built in under the oil filter, to control all the oil filter flow that spills out when unscrewing it. It was a genius idea, I have never gotten a drop of oil on my hands.
Old Aug 2, 2010 | 06:30 PM
rengnath's Avatar
rengnath
my old S-10 had something similar. I thought it was slicker then crap back then too. (the little oil slide)
Its amazing how the simple things amaze us.
Blown, your truck may have a supercharger .... but monkey has a slide below his oil filter Do we have our next TOTM canidate?
Jk guys
Old Aug 2, 2010 | 07:38 PM
MonkeyWrench4000
Jk guys
haha. A little common sense in a design does go a long way.
Old Aug 3, 2010 | 08:21 AM
lghtngblt02
Monkey does that slide have a Part Number? It would be awesome if I could order one from the dealer Then I was be mess free with the fumoto valve and the oil slide
