oil pump
Old Aug 10, 2010 | 06:19 PM
ruger226's Avatar
ruger226
Default oil pump
Does anyone know where to get a oil pump for a rear mount turbo like the sts kit has and how much psi is needed for this?
Old Aug 11, 2010 | 05:58 PM
dakotajerry's Avatar
dakotajerry
Get it from one of STS's dealers or go here http://www.pegasusautoracing.com/pro....asp?RecId=156 The pressure is adjustable. I don't remember what mine was set at. I'll have to look into it and see.
Old Aug 12, 2010 | 08:14 AM
dakotajerry
Where are you planning to run your oil return? If you're returning to the filler cap you will need the pump. If your turbo is level or above the oil pan you can just tap the pan and not need the pump.
Old Aug 12, 2010 | 05:22 PM
ruger226's Avatar
ruger226
I was planning on puting the turbo where the muffler was and i assumed that i need a pump. Also i called sts and they said that they wont sell just the pump
Old Aug 12, 2010 | 05:49 PM
dakotajerry
You will probably need one. Try locating one of the dealers and give them a buzz. They should sell you one. I'll see if i can find you a contact. There was a guy out of texas i was getting parts from.
Old Aug 13, 2010 | 07:31 AM
ruger226's Avatar
ruger226
Thanks man and what size turbo do you think i should run im only looking for about 8lbs of boost
Old Aug 13, 2010 | 09:06 AM
dakotajerry
On a stock 4.7L for a daily drive I would go with a Turbonetic 60-1 with a .68AR You will get hardly any turbo lag. Do you have the Magnum or HO 4.7? HO is a higher compression motor so you won't be able to put too much boost to it as a Magnum.
Old Aug 13, 2010 | 10:08 AM
dakotajerry
PM sent on contact
