engine swap question
Old Aug 16, 2010 | 10:59 PM
lmrjason's Avatar
lmrjason
Default engine swap question
not that i'm gonna do this but i was just curious what it would take to do an engine swap from the old 4.7 to the new 4.7. Doesn't seem like it would be to difficult and if you could find a pretty new engine in a junk yard for a decent price it could be a pretty worth while upgrade. Plus you could recoup a little bit of you money back from your old engine. just a thought.
Old Aug 17, 2010 | 01:40 PM
dodgetrucker75's Avatar
dodgetrucker75
i think if you wanted to do it, the best way would be to swap the entire top end, i believe the bottom end is all the same, but i guess the pistons could be different, due to the heads, but you can get an adapter to run the cable operated TB and there is still only 8 coils, they just run two plugs each, and who knows they may have the same connections and possibly beable to run the entire pre 08 wiring, looks like we need to do some comparisons
Old Aug 17, 2010 | 08:22 PM
lmrjason's Avatar
lmrjason
would a throttle body adapter solve the gas pedal problem?
Old Aug 17, 2010 | 08:55 PM
dodgetrucker75
yes it would
Old Aug 17, 2010 | 09:20 PM
trucky's Avatar
trucky
The PCM on the new 4.7 is not supported by our engine or SCT tuning.
Old Aug 18, 2010 | 02:15 AM
WTEBOY703's Avatar
WTEBOY703
true gotta remember that fact too!
Old Aug 18, 2010 | 06:32 AM
lmrjason's Avatar
lmrjason
where are the hiccups gonna be at with trying to run this engine with the 05-07 pcm or is it not possible.
Old Aug 18, 2010 | 06:34 AM
lmrjason's Avatar
lmrjason
Originally Posted by dodgetrucker75
...but you can get an adapter to run the cable operated TB...
my bad i didn't catch that you already addressed it.
Old Aug 18, 2010 | 07:09 AM
WTEBOY703's Avatar
WTEBOY703
i think they just need to go ahead and drop the 5.7L in the Dakota and get it over with! I mean how saweet would that be?
