Tailgate rattle
Old 08-26-2010, 05:35 AM
Cuban11182's Avatar
Cuban11182
Cuban11182 is offline
How about just take the tailgate off, and then drive around to see if the sound goes away?
Old 08-26-2010, 07:37 AM
motodeficient's Avatar
motodeficient
motodeficient is offline
Now thats a pretty good idea. I will give that a try. Thanks.
Old 08-26-2010, 09:34 AM
00dakSport's Avatar
00dakSport
00dakSport is offline
do you have a quad cab? on the older dakotas they had a "stabilizing bar" forward of the hitch. it fits into rubber gromets and when these wear out there can be a rattling noise.
Old 08-26-2010, 09:35 AM
motodeficient
I have a club cab
Old 08-26-2010, 10:46 AM
blakdak07's Avatar
blakdak07
blakdak07 is offline
Do you have your spare tire under there and is it tight?
Old 09-25-2010, 10:19 PM
Bajabob's Avatar
Bajabob
Bajabob is offline
Motodeficient, I had a similar rattle and changed the rear stabilizer links and the noise decreased but didn't go away. So I was able to narrow it down to the shocks. When I had the truck up on jacks I was able to recreate the noise by pushing up on the bed from below. I removed the shocks and the noise was eliminated. So i need to get new shocks. In the meantime I tightened the bolts real tight and the noise is still gone. Hope this helps.
Old 09-26-2010, 04:52 AM
Ueland's Avatar
Ueland
Ueland is offline
you might also check the exhaust hangers could just be your pipe bouncing against the frame or the body....
Old 09-26-2010, 06:05 AM
WTEBOY703's Avatar
WTEBOY703
WTEBOY703 is offline
so whats the verdict did it go away or not?
Old 09-26-2010, 10:47 AM
Six_Shooter's Avatar
Six_Shooter
Six_Shooter is offline
This was my first though on diagnosing the problem.
Old 09-27-2010, 07:38 AM
motodeficient
I haven't really looked into it. I have new ranchos on there so I don't think thats the problem. I will get back with you guys once I get some time to investigate. Thanks!
Quick Reply: Tailgate rattle
