Build sheet
Old Sep 2, 2010 | 01:24 PM
ruger226's Avatar
ruger226
Default Build sheet
Has anyone got a wrong build sheet beacuse i got mine today and it says that i have a v6. Has this happened to anyone else? Everything in bold is wrong.
*P9 Cloth 40/20/40 Split Bench Seat
-D5 Med Slate Gray
ADJP Heavy Duty Service Group
AHC Trailer Tow Group
APAS Monotone Paint
A62P 3.7L Eng(EKG)/4Spd A/T VLP(DGV)
BAZS 136 Amp Alternator
BCQP 750 Amp Maintenance Free Battery
BCSS Run Down Protection Battery
BGJS Pwr Disc/Drum Rr Anti-Lock Brakes
CBEP 40/20/40 Split Bench Seat
CFR Rear 40/40 Folding Split Seat
CGZS Passenger Air Bag On/Off Switch
CG3S Advanced Multistage Front Air Bags**
CKES Front Seat Area Carpet
CSRS Passenger Assist Handles
CSWS Driver Assist Handle
CTWS Vinyl Door Trim Panel w/Map Pocket
DGBS All 4-Speed Automatic Transmissions
DGV 4-Spd. Automatic VLP 42RLE Trans
DHAP Lock-Up Torque Converter
DMDP 3.55 Rear Axle Ratio
DRAS Corporate 8.25 Rear Axle
DSA Anti-Spin Differential Rear Axle
EKG 3.7L V6 Engine
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEGS Deep Tint Sunscreen Glass
GJDS Rear Fixed Window
GNAS Rear View Day/Night Mirror
GNDS Driver Side Sun Visor
GNES Passenger Side Sun Visor w/Mirror
GRUP Left Manual Mirror
GSUP Right Manual Mirror
GTUS 5 X 7 Mirrors
HAAS Air Conditioning
JAAS Instrument Panel
JAYS Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
K8AS STRIPE/BADGE/MOLDING COLOR
LAFS Key in Ign/Seat Belt Warning Buzzer
LAJS Headlamps On Warning Chimes
LALS Low Washer Fluid Warning Signal
LAMS Door Ajar Warning Lamp
LCDS Map/Dome Reading Lamps
LCHS Rear Dome Lamp
LMBS Halogen Headlamps
LPES Cargo Lamp
LPSS CHMSL Lamp
MBZS Dark Gray Rear Bumper w/Step Pads
MCCS Dark Gray Front Fascia
MFDS Bright Grille
MGAS Ram's Head Badge
MHAS Black Windshield Moldings
MUMS Dakota Badge
NAS 50 State Emissions
NBKS EVAP Control System
NBQP Federal Tier 2, Bin 10A Emissions
NFBS 22 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHFP Power Steering Cooler
NMCP Heavy Duty Engine Cooling
NZDS Next Generation Engine Controller
PSB Bright Silver Metallic Clear Coat
QSBS Bright Silver Metallic Clear Coat
RCDS 4 Speakers
RDDS Fixed Long Mast Antenna
REFS AM/FM Compact Disc Radio
SBAS Power Rack and Pinion Steering
SCDS Luxury Steering Wheel
SDBS Heavy Duty Suspension
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SHFS Rear Stabilizer Bar
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TVFS P245/70R16 BSW On/Off Road Tires
TZAP Goodyear Brand Tires
WDQP 16" Steel Spare Wheel
WNPS 16X7.0 Styled Steel Wheels
XBSS Pickup Box
XCAS Occupant Classification System
XDXS Scissor Type Jack
XFHP Class IV Receiver Hitch
XFKP 7 Pin Wiring Harness
XSLS Brake/Park Interlock
X81S Instrument Panel Parts Module
X88S Tire & Wheel Parts Module
YAAS Build To U.S. Mkt. Specifications
Old Sep 2, 2010 | 02:56 PM
hwcurtice's Avatar
hwcurtice
Seems odd they got the engine wrong.
Did you buy the truck new or used? If used, it's possible the PO did some Mods to it. The spare tire is wrong?
I'd resubmit the VIN and have them recheck. Maybe you got a number flipped?
Old Sep 2, 2010 | 05:35 PM
Blown287's Avatar
Blown287
I would double check the VIN you sent to ensure its the right one. 1st time I've seen that big a discrepancy on a build sheet. Plus you can email them and ask them to double check.
Old Sep 2, 2010 | 05:45 PM
trucky's Avatar
trucky
Are you sure you don't have a rear bumper with the plastic step plate on top?
Old Sep 2, 2010 | 07:06 PM
ruger226's Avatar
ruger226
I have a step plate not a dark grey bumper and for the spare its a 225 not a 245 so to me thats not full size because you dont want to run an oddball sized tire. But still i dont have a v6 im gonna try this again and see how it goes.
Old Sep 3, 2010 | 10:52 AM
Buckmaster's Avatar
Buckmaster
I'd say your spare has probably been replaced with that, before you got the truck... you still don't have a v6 though...lol
Old Sep 3, 2010 | 11:30 AM
WTEBOY703's Avatar
WTEBOY703
yeah...i think when it says "MBZS Dark Gray Rear Bumper w/Step Pads" i looked up that code and it is typed wrong...MBZS means the actual step part on the bumper...but the front bumper is deffinately wrong! lol idk double checkthe build sheet you got to your vin number...are you sure its right? Also the passenger airbag on and off thing is in the middle of your dash above the radio...i ahve that and are your mirrors elctronic or do you have to move them yourself?
