what size tires should i get
Old Sep 3, 2010 | 10:33 PM
Hinkster15's Avatar
Hinkster15
Default what size tires should i get
I have a 2003 dodge dakota sxt. Right now it is stock lift. but in the future i am looking at putting a body lift on but it might not happen. so whats the biggest tires i should get. I was thinking 31s or 33s. But i am worrying about rubbing inside the tire well. what do you think
Old Sep 3, 2010 | 10:41 PM
fenwayfan25's Avatar
fenwayfan25
My truck is stock and I run 31's with no rub at all. I don't think there is room for the 33's
Old Sep 3, 2010 | 11:11 PM
rengnath's Avatar
rengnath
I believe the 2nd gens have a higher front end than the 3rd gens .... atleast the ones that I always see. Maybe they have leveling kits. Either way, you may want to ask this question in the 2nd gen Dakota section; they will be able to give you a more accurate answer. By the looks of it, you probably will be able to fit a larger tire on your stock 2003 than we can on our stock 2005-2010s.
Old Sep 3, 2010 | 11:51 PM
Eimer123's Avatar
Eimer123
I had a 2000 Dakota before and I was able to fit 32.5" tall tires stock. I have heard you can fit 33" with no rub if you crank the torsion bars.
Old Sep 4, 2010 | 12:07 AM
lootownpunx's Avatar
lootownpunx
i had 31/10.5's on my 98'
they were a set of cooper atr's they fit really well as a stock tire...im sure you could fit a 32/12.50 tire on with a torsion bar raise,33's it be wise to put that body lift on and a torsion lift.
