Remote (key fob) died
Old Sep 7, 2010 | 11:35 AM
Jaded's Avatar
Jaded
Default Remote (key fob) died
Couple days ago I pulled the cables off my battery and gave it and the terminals a good cleaning. Next day my wife is complaining that her remote is not working. So I looked in the owners manual and followed the programming steps using my remote (which still works) with no luck. Put a new battery in her remote and tried programming a few more times with no luck.
Is there any way to actually check this remote? Could just be coincidence that it busted at the same time I disconnected my battery.
Old Sep 7, 2010 | 12:31 PM
sdsdsd's Avatar
sdsdsd
I had two remote keys die. If you take them apart you will find cracked solder joints around the button area. Just reflow the solder if that is the case and it will work again.
Old Sep 7, 2010 | 02:53 PM
rengnath's Avatar
rengnath
Autozone and advanced normally have an RF radio frequency tester you can try where they sell the batteries and that will tell you if the remote is putting out a signal at all
Old Sep 7, 2010 | 08:04 PM
trucky's Avatar
trucky
If none of that works, the dealer and ebay charge a lot of money for new keys/programming. You are better off getting a viper alarm at that point for the same/less cost.
Old Sep 7, 2010 | 09:27 PM
I'd do what trucky said if mine ever goes out. that way I can get a remote start as well as a decent alarm!
